Question about Oki Electric Industry B431d Printer
Reset drum okidata b431dn+ - Oki Electric Industry B431d Printer
I'm trying to use the multi-purpose tray. Can't get it to work. Thanks for any help you can give.
go into printer menu usually under paper handling menu and be sure manual feed is not turned off. If not check printer set up in computer by going to the printer in devices and printers and click on the properties menu and set up for manual feed.
Apr 24, 2014 | Okidata Oki Data B431dn Laser Printer...
I changed the drum and there's still a message saying order drum....is there a way to reset that?
(from Okidata's support site)
After replacing the image drum cartridge, reset the drum counter to keep a correct count of the number of pages printed on the image drum.
1. Turn the printer on while holding the MENU 1/Menu 2 button. USERMNT displays in the control panel window.
2. Press MENU 1/Menu 2 three times. DRUM CNT RESET displays.
3. Press ENTER. The counter will reset and the printer will go ON-LINE.
Jun 30, 2010 | OKI Electric Industry B4600 Laser Printer
My printer says set drum/toner cartridge. How?
RESET OKIDATA TONER DRUM
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Jul 28, 2009 | OKI B6200 Laser Printer
Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
Okipage 14e drum rest process
From memory, I think you enter maintence mode my power on when holding down menu key then arrow to drum reset. If not post back and I'll look at user manual
Jan 18, 2008 | OKIPAGE 14e Led Printer
Okipage 8w print drum
To reset the drum counter on these it can be done by this
link to oki 8w Image Drum Cartridge instructions
http://my.okidata.com/man-8w.NSF/MOCContents/5577D9A2FD2AC576852566C100507580?OpenDocument
or if I explain it, go to printers and faxs on your pc find the oki icon for your printer right click it and propertys.... go to printing preference tab, look in there....
If you are having image problems with new drum, I doubt any reset will help.
Post back any issues or check link below chapter 5
http://my.okidata.com/man-8w.NSF/InsideUsersManual?OpenFrameSet
Nov 13, 2007 | OKIPAGE 8W Led Printer
Resetting image drum
U need to go on the program in your computer and from there reset the drum, probably u have one called okidata, ther u have a OP8z monitor.
Jan 15, 2007 | OKIPAGE 8z Led Printer
Oki Electric Industry B431d Printer Logo
26 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Victorman
Victorman
Tony
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
