Question about Kenmore 88732 Top Load Stacked Washer / Dryer
I need to get to the lid switch on my stackable laundry center.
How do I open the front panel on the washer to get to the lid switch. I need to put a nut on one of the screws that holds the lid switch and can't figure out how to get to it.
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Frigidaire stacked laundry center lid removal
2 screws top corners back push lid back from front
Feb 26, 2015 | Frigidaire Washing Machines
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
Hi Guys, I have a Whirlpool stackable washer model # LCP-4332-PQ1...I ran it for one load and it was fine...I unloaded it and went to get more laundry for another load...When I left, I left it...
Hi rcdrivertim,
I believe the problem is the Lid Switch. Find it here:
http://www.appliancecarestore.net/whirlpool-amp-kenmore-genuine-washer-lid-switch-.html
If the Lid switch does not work, the machine will not switch over to cycling, thus not work.
You could always test the Lid switch by switching the attached wires to continuity, also known as bridging.
Hope this helps :-)
If this answered solved your problem, please accept it. If it did not, please comment and I will help you further.
May 02, 2011 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
I have no power to my machine. the plug is in and the the fuse box is fine in the house and still the machine wont turn on. i started a load of laundry and it lost power befor it finished.
If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't work until you replace the fuse.
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Maytag stackable washer top loader
try replacing entire lid switch assy, come ith new fuse!
Oct 31, 2008 | LG WM2077CW Laundry XL Front Load...
try unplugging from the power and starting again
Jul 30, 2008 | LG WM2077CW Laundry XL Front Load...
Maytag stackable w/d
Yes, it is inside the front washer lower front panel. Turn off poawer to unit and change w/ 1Amp 250V (regular of slow-blow). Then try only opening washer lid door with full dial pushed in (that would be the 'off' position. Only open/close lid w/ dial in off position. If washer works normally, may have a temp solution. Mine started this way, but ultimately the double relayed door lid switch was going bad and I had to replace it. Instructions/pictures below. Good Luck
AT702
Jan 27, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
