Question about Sony KP-53XBR45 53" Rear Projection Television
Double picture & color problem
Hi my 53'' sony rear projection big screen manufactured n 2000 has double picture words and color, it has green words and green picture above everthing else. it also has a double border on the left side of the screen. while in service mode under the convergence screen i tried to fix my problem but only made it worse, i tried alligning up every color including green and when i use flash focus it didnt work E11G appears.
  • Sony Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akaidouble picture & color problem - 2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 22, 2010
I have big screen (53") Soni TV that I had bought
Hi this is a common issue on this sets I also have the aame problem with my sony ,whats your model number?
Apr 18, 2011 | Sony Televison & Video
Sony color rear video projection, Sn 9720391, model KP65WS510. Looks like 3D without glasses. Red double words and pict are shadowy
Common problems with rear screen projections. Either you need to refocus the alignment, or you need to have the Convergence IC's replaced. In your owners manual, it should tell you how to refocus the alignment.
Feb 15, 2010 | Toshiba 53H71 53 in. Rear Projection...
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
How do I stop from getting double pictures on my KP-53XBR200 53 in? And Stop the color green from going of center with the rest of the other colors?
Could be a convergence adjustment from your remote under MENU. (This can be done by you)
Could be a problem in the convergence circuitry. (This can be done a TV tech only)
N Sabre
Nov 07, 2009 | Sony KP-53XBR200 53" Rear Projection...
Panasonic Rear Projection Screen TV
you need new convergence chips, there are 2, part number stk 392-110, also you must check for burnt resistors, if you don't have very good soldering skills at least, you will need a tv repairman.
Sep 15, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Picture and writing in 3d
replaced both convergence ics.the red green and blue colors are not converging.these ics are two big black ics.
Jul 28, 2009 | Sony KP-53V75 53" Rear Projection...
Color not working on 53" rear projection sony tv made in 2000 looks like color is all green is it a tube because of the year
there's a slight possibility it might be your video board, i recommend disocuntdashmerchantdotcom for free troubleshooting :)
Jul 01, 2009 | Sony KP-53V90 53" Rear Projection...
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
The words on the screen is doubled or trippled.
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Nov 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
159 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
