Question about Dell E197FP LCD Monitor
Can i attach dell soundbar as501 to monitor e197FP
  • 5 Answers
SOURCE: Speaker Bar connection
There are 2 placces on the underside of the monitor for the speakerbar to slide into. For that model You will probably need the external power supply.
Posted on Jun 23, 2008
SOURCE: Dell E197FP LCD Monitor won't turn on completely dead
From Matosml
Thank you all for the suggestions it turned out my PC was still under warranty so they send us a new monitor:-)
Posted on Jul 09, 2008
mpapog
  • 148 Answers
SOURCE: parts list for dell e197fp lcd monitor
Try on these sites for _> perts http://www.bizrate.com/monitor-parts/
and here documentation -> http://support.euro.dell.com/support/systemsinfo/documentation.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&~subcat=54&~cat=3
Posted on Feb 24, 2010
budmrtn
  • 11361 Answers
SOURCE: My Dell E197FP was working fine, i sold the system
You need to try it out with another PC, if it still does not work, you will need to open it up and inspect the inside. If it works, then try reseating the video card inside the PC.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Posted on Apr 22, 2010
invisiblade
  • 6 Answers
SOURCE: Dell E197FP Monitor Windows 7 driver
On dell site:
http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection
Posted on Nov 24, 2011
How do I replace sound bar on monitor?
Deb Powell,
Reverse the steps listed below. They are for connecting the sound bar.
1. Working from the rear of the monitor, attach the Soundbar aligning the two slots with the two tabs along the bottom rear of the monitor.
2. Slide the Soundbar to the left until it snaps into place.
3. Connect the Soundbar with the power brick.
4. Plug the power cables of the power brick into a nearby outlet.
5. Insert the lime-green mini stereo plug from the rear of the Soundbar into the computer's audio output jack.
NOTE: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only.
NOTICE: Do not use with any device other than Dell Soundbar.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 16, 2016 | Dell E197FP LCD Monitor
The Dell AS501 doesn't seem to want to connect to my Dell E196FP Monitor.
If there is a power connector for the soundbar, it should be on the bottom of the monitor where all the other connectors are located.
Mar 25, 2014 | Dell E196FP 19" LCD Monitor
The stand of my E173FPs monitor is broken. What can I do?
Sorry to hear that the stand had broken on your monitor.
many times there is a mounting in the center of the monitor back that accepts a standard 4 screw mounting, which almost any brand monitor will fit on, many of these type stands will adjust in height and also sometimes rotate to a portrait if you should like to read documents with the narrow side to the top.rotated 90 deg. some monitors do not have this option the mount is called (VESA mounting holes, 100mm (Behind attached base plate) but eBay is a great course for this type of part. I should have one of the Dell original mounts in my older parts area. but i see (Problem with Dell E197FP LCD Monitor) and (E173FPs) both in this unsolved problems, and knot knowing exactly the broken area, not sure of all you need to repair the broken area in question. Sprint6@zoominternet.net for personal help with this unit.
Dec 03, 2013 | Dell E197FP LCD Monitor
Does a Dell E197fp monitor have built in speakers
Not in the monitor, there is a sound bar that attaches to the bottom of the screen that is optional that added speakers to that model.
Sep 24, 2012 | Dell E197FP LCD Monitor
How to remove sound bar AS501
There is a clip near hook by pushing it.It will unlock the bar and slide it to right in horizontal position but in tower position it will slide to left7_22_2012_10_18_04_pm.jpg
Feb 17, 2011 | Dell AS501 SoundBar 2 Speakers
Blue light comes on AS501 Flat Panel Speakers, but there is no sound.
After reinstalling/installing an Operating System you can lose the Audio Drivers or sometimes they just corrupt.. Try reinstalling the Audio Drivers from the disk provide with your P.C./Laptop. If you no longer have the disk just visit the website of the makers of your P.C./Laptop or Motherboard and download the Audio Drivers from there, after that install them.
Thumbs up please if this works for you, thanks.
Aug 26, 2010 | Dell AS501 SoundBar 2 Speakers
I have a 4.5" black strip running down my 2001 fp monitor screen. What do I need to correct it.
Note: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only. .
DO NOT USE WITH ANY DEVICE OTHER THAN DELL SOUNDBAR.
  1. Working from the rear of the monitor, attach Soundbar by aligning the two slots with the two tabs along the bottom rear of the monitor.
  2. Slide the Soundbar to the left until it snaps into the place.
  3. Insert the black DC plug from the power cable at the back of the Soundbar into the DC Jack on the back of the Flat Panel Monitor.
  4. Insert the lime green mini stereo plug from the rear of the Soundbar into the Computer's audio output jack.
Jan 16, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell E197FP LCD Monitor Logo
49 people viewed this question
Alun Cox
