Question about Samsung RS2556 Side by Side Refrigerator
Freezer defrost all. RS2556
I noticed water dripping from the water and ice dispencer. I used the ice dispenser to get ice and it came out mostly melted. The freezer was meting everything inside. The fridge was ok, 40F. The panel had the freezer temperature blinking at 2F, but if I pressed the temperature button for the freezer nothing happened. Finally I unplugged it, and plugged it again after 10 minutes. The freezer temperature stop blinking and it was now 74F. The freezer started working again. How could that happen? It looks like the freezer went in defrost mode and stayed there. One doubt I had was the I got some ice and the little ice door got stuck. Would that trigger that defrost reaction? When I plugget it again I heard a strong noise, the same I hear a couple of seconds after having gotten ice. What else may have done it? Thanks
  • Anna Zac Sep 02, 2007
    Thank you, that could be it.
    I was surprised tought that all happened in less than 3 hours. I opened the freezer 3 hours before and everything looked right.
  • 183 Answers
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Posted on Aug 31, 2007
Water collecting on top shelf of refridgerator
Your defrost drain line in the freezer has stopped up. The defrost water is coming in through the air vent to the fresh food section.
Turn the unit off and use a hair dryer to defrost the drain hole located behind the freezer panel.
Jun 21, 2011 | Kenmore Top Freezer Refrigerator
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer won't reached desired temp or make ice
Most definately you do. somehow air got in while you were away. 12 hour defrost with doors open will help.(insulation in side by side normally thick).Had one like that approx. 2 months ago but fridge was not well treated and they damaged rubber seal at water and ice dispencer area.
Jun 06, 2010 | Bosch B20CS51SNI Stainless Steel Side by...
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2010 | Freezers
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Water dripping from inside of freezer compartment.
The condensate drain has a blockage further down and possibly in one of the turns as it leads down to the pan below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie2.gif that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
- Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 24, 2009 | Jenn-Air JCD2389G Side by Side...
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water accumulating in bottom of freezer
The water was not coming from the dispenser or the ice maker. It is a result of a plugged defrost drain tube.
When the refrigerator goes into defrost, if the water is unable to get out the defrost drain, it ends up on the floor of the freezer. You will have to clear out the defrost drain. It is a tube which is behind the back wall of the freezer compartment, at the very bottom of the cooling coils. Use a turkey baster with hot (not boiling) water to flush it out until the water runs out the drain (and into the defrost drain pan under the refrigerator where it will evaporate as the fan blows air over it).
Dec 10, 2008 | Frigidaire Refrigerators
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Samsung RS2556 Side by Side Refrigerator Logo
266 people viewed this question
Top Samsung Refrigerators Experts
Paul
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
