Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon mp 260 error e8 - Canon PIXMA MP160 All-In-One InkJet Printer
2 Suggested Answers
lock123
  • 6831 Answers
SOURCE: Error E8 on Canon PIXMA MP 150 printer. It will
Hello
Here is something you can try, all credit Ben k:
(1) have your printer power down ie. off, just to make sure pull the plug out and wait 10 seconds.
(2) plug printer back in, now Hold down the Stop/Reset button don't let go.
(2a) push and hold the on/off button
----at this point both fingers are holding down the buttons.----
(3) take your finger of Stop/Reset, pause maybe a second now press stop/reset button once and then press again and hold.
--- both fingers at this point are hold down both buttons----
(4) take your finger off on/off and now finally take your finger off stop reset.
---wait for the printer to go into its service mode ie. wait maybe 30 secs a min whatever till the printer carage has moved back into ints original spot.
---after this has occoured you should be able to press Stop/reset to cycle though the options
each time you press Stop/Reset Alarm and on/off should alternate lighting up. Hope this helps.
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Hope this helps good luck
Posted on Dec 08, 2009
Hp laserjet 1132 mfp e8 error code, how do i solve this
Hi Abu Bakarr.
The e8 error is refering to problems with the CIS Scanner. I have attached a link to the product service manual. Read page 122 about the e8 error and perform the 4 steps in the manual to fix the problem. If no luck, the CIS Scanner needs to be replaced. Good luck. http://www.feedroller.com/store/Service%20Manual/HP_LJ_M1130_M1210_Manual.pdf
Jan 10, 2014 | Canon PIXMA MP150 All-In-One InkJet...
Tip
Error P22 CANON PRINTERS MP 240-250-260-270-280
If appears error P22 at this printer CANON MP 240-250-260-270-280 means you need to replace first the scanner,if the problem persist you need to replace the logic board.
on Apr 06, 2011 | Office Equipment & Supplies
When I switch on my Canon Pixma MP 160 Printerr, the display flashes "E8" Error message. Please give me a simple solution step-by-step to solve this problem
Welcome to Fixya
E8 = Waste ink absorber full or platen waste ink absorber full. The first thing you need to do is Press or button to clear the error and continue printing. If still the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 26, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I need the driver to doun load it for my laptop lg c500 window 7 pinter and scanner driver . thanks my ,printer is canon mp 260 pixma
Go to website of the manufacturer of the printer download drivers,,search for windows 7 drivers,,goodluck,,canon website,,and try laptop wesite also.
Nov 19, 2010 | Computers & Internet
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp190 error code e4
My canon mp190 gives E3 paperjam error but there is no paperjam, how do i fix it?
Jan 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp150 error code E8 does this mean that the printer is useless even though we have cleaned the ink pads?
Re ; Canon MP150 printer error "E8".
We found a blog that explained that once this error appears, even if you clean the ink pads as we did you cannot erase the error message. Therefore unless you pay a call out fee, not worth it in comparison with a replacement printer, the printer is of no further use. An "extermination" code it would appear!
Jul 22, 2008 | Office Equipment & Supplies
Mp 160 don't work
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
360 people viewed this question
old marine
old marine
