Studio 35 F10 error
I have a studio 35 with F10 error, the problem is: When The machine is in test mode (08) the display is freezing and is not possible to run it to system mode¡ Is possible that is necesary update the firmware? I have connection between the PC and Copier, but I do not have the files¡ Help?
Thanks,
Adalid
  • troyramos Feb 01, 2009
    Thanks for yours tips¡
    I have tried with differents HDD (new and used but in good conditions) all I have placed them in " master " and the problem still continue. I placed 08 and the display shows "test mode" in some cases is not possible put 690 because it is freezes. In all the tests, I put 08, after 690 and never changes to "system mode". Again is freeze¡
    in fact only the mode 01 ( light test) works¡¡.
    I can do the serial conection with a PC, it works very good, but
    I don't have Program dates sysfirm.tz - Fixed UI uidataF.tz dates - Common UI uidata0.tz dates - 1st language UI uidata1.tz dates - 2nd language UI uidata2.tz dates - 3rd language UI uidata3.tz dates - 4th language UI uidata4.tz dates - 5th language UI uidata5.tz dates to upgrade the firmware.
    I am going to check the firmware version but I thing that it is old less than 17¡
    Thanks Again¡¡
    Novelist:
  • 126 Answers
Error F-10 = HDD problem
F-10 fix; do 08-690 which will probably get the machine running again unless the HD is totally fried. You can replace the hard drive with any hd as long as the firmware version is 17 or higher. If you take off the inner tray you can see it buried in the middle under a plate and a board. Make sure that the HDD is set to 'master' when replacing.
Posted on Jan 24, 2009
Test mode D comes up in toshiba e studio 207 by pressing 0 and 8 button during power on the machine a test mode D comes up so what I do ?
Practically you can exit by pressing 0&9 together and it will come to ready mode.You will see this kind of display only when you want to enter the service mode, now you will have to enter a value eg., if your machine gives error c44, then you can go to service mode and then enter 400 to reset the error.
Jan 20, 2015 | Toshiba e-Studio 207 Copier
Error c41 studio 35
08-400-0-set-off/on
check thermistor
thermal fuse continuity
Dec 05, 2013 | Toshiba e-Studio 35 Copier
I have a toshiba studio 35 copier that displayes call for service, how do i reset it?
Press CLEAR+8 to check the error message.
If Cxx, perform 08-400, reset any value to "0"...
Feb 20, 2012 | Toshiba e-Studio 35 Copier
Sir i would like to enter the diagnostic mode of the machine
Hello
There is two codes the 05 and 08 codes. To enter these codes switch off the machine, while holding down the 08 or 05 buttons and switch the machine on, remove the fingers once the machine is on.
The other diagnostic mode , while the machine is on press the user function buttone and then on the display press the password flag and enter 123456 and press enter.
I hope you sucseed.
Regards
Jul 24, 2011 | Toshiba e-Studio 350 Copier
What does error message F103 mean?
Hello
Before we start to get the machine into the test mode, switch off the machine while holding down 0+8 buttons switch the machine on and then input 694.
The error that you have is explained below.
[F103] HDD transfer time-out.
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of the harnesses are broken.
(3) Perform the bad sector check (08-694)
(4) If the check result is failed, replace the hard disk drive.
Regards
May 11, 2011 | Toshiba e-STUDIO 352 Black and White...
Error F105
Hello
Lets try the following.
(1) Check if the connectors of the hard drive are disconnected.
(2) Check if the connectors pins are disconnected or the wires of the harnesses are broken.
(3) Perform the bad sector check (08-694).If the check result is failed, please replace the hard drive.
(4) Before you replace the hard drive do a format (08-690).
To do this please switch off the machine.
While holding down 0+8 buttons switch the machine on, when in test mode input 690 and press the start button.
I hope this helps some
Regards
Apr 20, 2011 | Toshiba E-STUDIO 720 Copier
Screen appears error with thermistor,what i have to do?
switch hold down 08 while holding 08 down swich on machine wait until test mode starts on the number pad put in 400 and press start input 0 and set switch off wait 30 seconds and swich if error code c440 is back you have to replace thermistors and thermofuse
Mar 06, 2011 | Toshiba e-studio 455 Copier
Display F120 error in my Toshiba etudio 230
F120 indicates database abnormality.
What u can do:
1. Rebuild the database ( 08-684 )
2. If the error is not recovered, initialize the HDD. (Enter “2” at 08-690.)
PS: Press "0+8" & ON the machine in order to enter setting mode.
Jul 28, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
Jul 22, 2009 | Toshiba E-STUDIO 650 Copier
Toshiba eStudio 211c
it is hard disk trouble. First enter in service mode (pressing 08 while turn on the power) next, type 690 and set to 2, click enter and wait the "reboot the machine" message, then turn off and on again
Apr 11, 2007 | Toshiba E-STUDIO 211C Copier
249 people viewed this question
k24674
jasbo
jasbo
