Question about Mitsubishi CS-40505 TV
My cs-40505 1995 wont turn on, the power supply from the wall is good. When I push the power button on the the tv nothing happens. Also the remote is stuck on cable.
Prior to this I had a black square in front of the picture.
MikeNJ1964
  • 398 Answers
SOURCE: Black square in middle of screen about 25in X 25 in
If a black square appears on the screen and you can see the picture around the edges, it means that the closed captions are on and set to "TEXT". Go into the TV's menu, navigate to the closed captions page and set the captions to OFF.
Posted on Aug 10, 2007
  • 1153 Answers
SOURCE: TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Posted on Sep 21, 2007
rsheehan
  • 69 Answers
SOURCE: My Mitsubishi ws-65819 won't power up. When I use
Unplug it ,leave it unplugged for at least an hour.
now slowly plug back in , if you notice a small spark coming
from the plug when you plug it in that's normal
which means most likely the regulator or output tran is out.
is about 150.00 200.00 normal cost. no more.
If the plug doesn't spark at all when you plug it in slowly
could be a Fuse :>
Posted on Jun 28, 2009
  • 17 Answers
SOURCE: model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Posted on Jul 15, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: The TV is a Mitsubishi CS-26201C to the extent it
The child managed to press the button on the remote that controls closed-captioning, and now the TV is set for "text" mode. I don't remember if the button says "caption" or "cc", but it's one of those or something very similar. Press the button again to go through the settings until you get back to "off" and the box will be gone.
What's happening is that in text mode, the TV blacks out the area where the text would go. If there isn't any, the result is that mysterious black square. It may not show up at all on some channels, or only during some programs. It depends on whether captioning is being broadcast. Since many TV remotes have a single button to control caption settings, it's easy to get into this mode without realizing it. But it's easy to fix.
Hope this helps! Thanks for using Fixya.
Posted on Nov 06, 2010
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
My tv has no power?
Let's assume your post in flat panel TV's is for an LCD TV. Since your make and model is not provided, only basic info can be provided. Most LCD TV's have a stand-by power LED that is either on or comes on when the TV switches or blinks in the event of a failure. If you don't see a light when there should be one normally, then you may have a failed stand-by power supply. The stand-by power supply provides a voltage necessary to allow you to command the tv to turn on with the remote or via the power button on the tv. If the power light is normally off and normally comes on when you use the remote to turn it on but nothing happens it can still be the stand-by power supply failed. The next level of the power control is done by a small tv micro (processor) often on a board that handles audio that tells the main power supply board to turn on. To render much technical assistance you would have to know how to take voltage readings on the PSU. If there is no SB5V you either need a PSU board or there is an issue from the AC line to the PSU. It can get complicated from there depending on the failure. I assume you know the power outlet at the wall is good and the remote battery is good and you have tried the power button on the tv to eliminate a faulty remote.
Dec 10, 2014 | Televison & Video
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
Tv wont come on at all..push the power button.. nothing, use the remote..nothing, not even a flicker...please assist
hi..this is probably an issue with the power supply
of the tv.check the power supply.
thank u..
kindly rate my response..
May 09, 2009 | Protron PLTV-37 37 in. LCD Television
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
TV wont turn on
just throw it out and never buy a sony again. Sony really went down hill
May 01, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
