Question about Raypak Pool & Spa
I have a Raypak R407a with an error code "FAN", what does it mean?
    Top Expert:
  • Raypak Master
  • 6,394 Answers
Fan motor
Posted on Apr 27, 2016
4 Suggested Answers
  • 246 Answers
SOURCE: raypak pool heater ser.#0606211992.
indicates false flame sensing check for flame rectification not touching ground like a piece of metal dirt or has been bend on the past
Posted on Aug 31, 2009
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
  • 990 Answers
SOURCE: my raypak heater has error
This is in the limit string. This is the string of safty switches in the heater. (thermostat, highlimits, rollout switch and pressure switch) The pressure switch is the most common problem. If the water flow get's to be too little so the water inside the heater is going to overheat than this will shut the heater down. This can be caused if your heater by-pass is to far open and letting water go by the heater. The most common problem is clogged baskets or a dirty filter. Other than this you can follow the flow chart in your manuel to find the source of the problem but if it just started without obvious cause this would be my bet.
I hope this helped and good luck.
Posted on Aug 31, 2010
I have iginition failure, no pilot sense
if you have proper gas pressure to the unit check to see if voltage to ignitor or if glowing that is ok then check to see if voltage to both sides of the pressure switch if not check to see if pressure switch wires are tight then check to see if the copper tube going to it is plugged if not check the high limits to see if corroded if voltage to gas valve and it doesnt open bad gas valve
Oct 09, 2014 | Raypak Digital Gas Heater Low-Nox Heater...
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Ign error code on a raypak rp2100 pool heater
ignition failure check gas pressure if ok see if ignitor is ok or safety circuit
Apr 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypac 407 ASME swimming pool heater Do you have a troubleshoot manual for this heater that I can download ?
if pump ok and filters ac going to unit check transformer if ok check safety circuit if ok on cycling check ignitor if ok check gas
Jun 20, 2011 | Raypak COMMERCIAL R407A 399K BTU ASME...
I have a 399k btu raypak and it will not fire. The ignitor just clicks and it's coding SPK, never gets any further in it's cycle.
Look at the ignitor when its sparking. If you cant visually see it spark, then its probably a bad ignitor. If it is sparking and still acting the same, then its a gas valve issue most likely.
Apr 22, 2011 | Raypak COMMERCIAL R407A 399K BTU ASME...
Raypak pool heater - error code is "FAN"
In models older than 07-07 it typically indicates a loss of the pilot light.
In models newer than 07-07 it is probably the air switch not being activated, or it has just failed. Check air switch tubing for secure connections.
Oct 03, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a raypak 2100 heater and it display a PLT code what can i do to fix it it tray to start but shoot down rigth a way
The "PLT" error code means pilot failure. The lack of spark may or may not mean an ignitor problem.
The "PLT" code could come up because the main valve in the heater was in the "off" position. No gas = no pilot.Also check clogged pilot-burner orifices. The lack of spark can also have to do with water flow issues (dirty filter, clogged basket, etc.), or it may be a problem with the electronics of the heater.
After checking the above, a service call by an authorized tech may be necessary.
You can also call Raypak at (805) 278-5300 for Customer Service
Sep 07, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak pool heater ser.#0606211992. mod.#C-R407A-EN-C getting the FFL code off to start falme?
Aug 30, 2009 | Honeywell Pool & Spa
Pool & Spa Logo
48 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
