Question about Whirlpool Washing Machines
Whirlpool whitemagic 650d machine is not retaining water
3 Suggested Answers
  • 833 Answers
SOURCE: water is not flowing into the machine
There are a couple of possibilities:
  1. Are the hot and cold valves open?
  2. If there are filter screens in the lines, are they clogged?
  3. If set to warm, does any water flow at all?
  4. If there is no water flow, first check the water level switch to see if it is working...this is located on the bottom of the machine...it is generally round and has a tube running to the tub and two or more wires.  It should have closed contacts to let the water valve work.
  5. If there is some water flow, the valve is likely bad or the supply is clogged.
  6. If the switch is continuous, the problem may be the timer.
  7. Is the water temp switch good?...unlikely.
Posted on Dec 12, 2008
mohankumar63
  • 223 Answers
SOURCE: I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Posted on Jun 19, 2011
Whirlpool top load 1-2-3 whitemagic it is showing 1E error why does this error come
your not getting proper water fill hot or cold water is not flowing into machine fast as it should check make sure water is turned on all the way or replace water valve
Dec 23, 2016 | Whirlpool Washing Machines
Whirlpool Washing Machine Whitemagic h70 Wiring Diagram
Can't seem to find one.
Is there a model# other than whitemagic h70?
I have had luck on parts places showing schematics when you start looking for parts in the machine.
Maybe that can work for you.
Nov 25, 2015 | Whirlpool Washing Machines
I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
whirlpool have a good fault code list on the net
go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
Jun 28, 2015 | Whirlpool Washing Machines
I get ESC error problum how to solve them
No water is detected having entered the machine. Check your water lines, make sure they're turned on and feeding water to the machine. If they are then you may have bad sensors in the washing machine. The ESC error occurs when no water is detected as having entered the machine. The Washing Machine upon not detecting water turns off the internal valves and kicks the error.
Jul 31, 2014 | Whirlpool Washing Machines
Whirlpool whitemagic pro 700h
The model no is Whirpool whitemagic pro 700H fully automatic top load
Dec 19, 2013 | Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I get a "PE" error
Jun 19, 2011 | Washing Machines
Error "LE" on the display after initial water load
just perform the tub cleaning operation as advised. nothing else. getting soiled
Mar 18, 2010 | Washing Machines
Water is not flowing into the machine
Dec 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
