Question about OfficeMax 0M96431 Shredder
Jammed Shredder Model OMO3521 - OfficeMax 0M96431 Shredder
Shredder jammed and motor doesnt turn on at all. I removed most of paper. What's next?
Look for overload reset button. But what happened with a model I had is that the blades bent and rendered the shredder useless and not fixable.
Mar 16, 2018 | Shredder Office Equipment & Supplies
How do I Clear a jammed shredder model EX12-05
unplug and take the top off and look for the jam of paper in the shredder rolls
use a small small screwdriver to remove the jammed paper
Dec 29, 2017 | Shredder Office Equipment & Supplies
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
Unclog a jammed paper shredder model MX80B ?
If reversing the shredder doesn't work, Unplug the power connection and look at the under side of the cutters and pull out all the paper.
Hope this helps.
Feb 21, 2015 | Shredder Office Equipment & Supplies
No power when pluged in - model OMO3521
Check if for any cuts on the cord. Make sure also that the power outlet is working. If everything is checked and still not powering ON, it is a possible power supply problem.
Mar 16, 2011 | OfficeMax 0M96431 Shredder
Jammed shredder
try shredding a old card, carefully but forcibly push the jammed plastic strip through the teeth.
might be faulty alignment of teeth, a factory defect!
May 07, 2008 | Aurora Electronics AS882C (Cross-Cut)...
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
OfficeMax 0M96431 Shredder Logo
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Steve
ka4iup
ka4iup
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
