Auto programing I have a phillips tv model # PC0125C321 with 0n/off, volume and channel buttons and I can't figure out how to program channels. I can get to the feature menu and thats it. Please help! Thank you!
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
  • 10 Answers
SOURCE: Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Posted on Feb 17, 2010
On my jvc tv model hd-61g787 I cannot program channels
you can program channel either in the remote control or in the tv button panel. press menu then go to manual fine tune so you can program the channel one by one. you can use the volume up/down button to tuned the desired channel. to select channel use the channel up/down button.
Jun 01, 2013 | Televison & Video
Need to know how to program philips model number CCC190AT32 without remote
There should be a setup/action or a menu button on the front of the t.v. Press that and use your volume or channel up/down buttons to navigate through the settings. Your looking for something that says auto program highlight it and figure out witch button on the front of the t.v is the enter button. Make sure that before you do the auto program that it's set for cable not air.
May 19, 2011 | Philips CCC193AT 19 in. TV/VCR Combo
I can't find my remote and i need to set the channel on 3 or 4 for my cable. how do i do that manually?
There should be a setup/action or a menu button on the front of the t.v. Press that and use your volume or channel up/down buttons to navigate through the settings. Your looking for something that says auto program highlight it and figure out witch button is the enter button. Make sure that before you do the auto program that it's set for cable not air. Once it's done searching you should be able to change your channel manually.
May 18, 2011 | Memorex MT2025D TV
I have an RCA 27in. screen TV. Cannot program, all is fuzzy.
try unplugging and plugging back in 2 minutes later. go to menu and find channel selection. scroll down to where it says channel. then using volume up and down buttons. will add or erase channel. just play with it and you will see what im talking about. go to channel 4 and press volume up. this will save channel 4 in memory. if no work, try turn on video souce and do a auto program in menu. fixed. enjoy!
Nov 09, 2009 | RCA F27252GY 27" TV
Cant get any channels between 34-98
If your remote does not have a menue to access auto channel programing, look for it on the TV itself. It may be hiding behind a small panel door, usually toward the bottom of the tv.Once you find it you may have to figure out how to bring the screen up that has programing feature. The screens usually can be brought up by channel or volume controls. Once the auto programing feature appears you push or press ok. If that does not work you should be able to manually key in each channel, one at a time. There as many variations as tvs. Hope this helps. Good luck. Larry
Aug 25, 2009 | GE 19GT317 19" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
Dec 07, 2008 | SansuiS3275 TV
Sansui TV/VCR 13" model COM311AD
on some tv's the menu can be accessed by pushing both channel up and down buttons at the same time. otherwise you may just have to get an all in one programmable remote control.
Mar 25, 2008 | Sansui COM311AD 13 in. Combo
Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Jan 15, 2008 | Televison & Video
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
