Question about Federal Industries 15 Amp Federal Pacific Stab Lock Circuit Breaker Thick
Replaced 15amp breaker and have no power now
I have a circuit that is not working and replaced the breaker and still nothing plus as I was not sure which breaker it was I changed another and it has now stopped working as well. i replaced the original breaker in this one which did work before i took it out and still nothing now what?
  • 10,865 Answers
It sounds like you are not reinstalling the breakers properly. look carefully at the other breakers to see how they hook around the hot bus bar. When the circuit breaker is installed properly you must push relatively firmly to have the breaker be seated on the bus bar. good luck
Posted on Jan 22, 2009
Circuit breaker keeps kicking off. nothing is plugged in and it still kicks off. i have changed the 15amp breaker and it does the same thing
It sounds like you have a power wire going to ground, which it should not. Please have a qualified person help you with this.
Mar 15, 2017 | Heating & Cooling
Bosch classic dishwasher
Circuit breakers do fail. You could swap a different 15amp breaker from another circuit to test this hypothesis, or just swap it with a new one. At least this way you'll know it isn't a power supply issue.
Feb 17, 2014 | Bosch Dishwashers
Is there a fuse for the power windows in a 2002 Ford Exlporer
There is a circuit breaker and a 60amp fuse in the box by the battery, plus a relay and a 15amp fuse in the central fuse box that affects the power windows.
The details should be in your owners manual.
Feb 04, 2013 | Ford Explorer Cars & Trucks
I have an ITE breaker panel (G2020MB1100) with Q115 breakers, but need to add a 15 amp circuit. Will a Q1515NC fit into one of the Q115 slots?
Yes they will fit. They are both a single pole breaker. Turn the breakers over. They should look the same and snap into a single slot in the panel the same.
Not sure what you mean by No Clip? A Square D QO Breaker has a metal clip that snaps into the panel on the breaker mount and one on the Bus Bar.
Feb 22, 2011 | Siemens Q1515NC Circuit Breaker Two1Poles...
The garbage disposal & overhead sink fixture run to the same Square D Qob120 1pole 15amp 120v Circuit Breaker . After a week of consistentlu tripping, the breaker won't allow itself to reset. ...
I would start by replacing the breaker. If a new one trips then check ground and wiring. If it still trips then there must be a problem with the garbage disposal. let us know
Sep 21, 2010 | Square D Qob120 1pole 20amp 120v Circuit...
Increase 15amp to 20amp breaker?
Hello
Take a look at the model number plate,somewhere the amps should be listed.
Add up the total for both freezers.One may be 8 amps the other 10.
So a 20 amp will work.Do not be more then 10 % over the total.
Jun 06, 2010 | GE Freezers
HAVE A ACR 2000 THAT WONT TURN ON,CHECKED POWER AT BREAKERS AND SWITCH HAVE 120 VOLTS
Please try the following: 1# Turn on the main power switch(ON/OFF) & press 15amp & 3amp circuit breaker at the same time to re-set the breaker.2#With line voltage is present at ''Main'' 15amp circuit breaker,Check connection between circuit breaker & power switch(ON/OFF).3# Verify line viltage is present at the power supply input connectior 44,(Brown=hot,Buue=neutral).4# Check connection between power switch & 15amp circuit breaker.Hope this will help you.
Mar 17, 2010 | Measuring Tools & Sensors
Looking for 2 15amp single pole pushmatic circuit breakers.
A Google search for "15 amp pushmatic" turned up several links. Here's one for a retailer with new ones and an eBay store with cheaper prices (maybe pullouts):
http://www.aplussupply.com/break/push/push.htm
http://stores.ebay.com/Sparkys-Place_Pushmatic-Categories_W0QQfsubZ10975954
Did you also check the big-box stores like Home Depot or Lowe's or electric suppliers in your area?
Feb 11, 2009 | Connecticut Electric & SWITCH UBIP130...
Federal Industries 15 Amp Federal Pacific Stab Lock Circuit Breaker Thick Logo
277 people viewed this question
Top Federal Industries Electrical Supplies Experts
Steve
Gene Haynes
Are you a Federal Industries Electrical Supply Expert? Answer questions, earn points and help others
