Question about Whirlpool WTW6400SW Cabrio Washer
Why does my whirlpool cabrio wtw6400w3 starts to wash and immediately stops?
It starts to wash and then stops but it still be lit up!
    Sergeant:
  • 291 Answers
Does the display show an error code?
Posted on Jan 11, 2013
SOURCE: Cabrio top load flashing F51
F51 error is a rotor position sensor error.Its a very common error in carbrio washers.heres a website just for this error.Refer for the solution through it.
http://cabriof51error.blogspot.com/2008/01/my-f51-experience-day-7.html
Posted on Dec 15, 2008
blueextc3221
  • 15935 Answers
SOURCE: start button not working on whirlpool cabrio
It sounds like your thermal fuse is out. You can check it for continuity with an ohm meter, make sure your dryer is unplugged first! Or you can take the wires off the thermal fuse and use electrical tape to tape them together to see if it will come on.
CLICK HERE for the TECH SHEET on your washer... and HERE to see the thermal fuse.
Sometimes the plastic start button can break a little tab off the back as well, so check it as well.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2009
  • 58 Answers
SOURCE: Whirlpool Cabrio wtw6600 stops at rinse and
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Posted on Mar 09, 2010
  • 12 Answers
SOURCE: My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
LOOK ON WIRLPOOL.COM AND LOOK UP CODES HIT THE CLEAR BUTTEN FOF35 SEC
Posted on Apr 03, 2010
  • 1382 Answers
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Posted on Jul 28, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My whirlpool cabrio washer will start to spin and then stop and show code f51 or f53
check is link for a repair manual and insight:
http://www.repairclinic.com/shop-for-parts/a11b121-x776869726c706f6f6c2063616272696f/whirlpool-cabrio-kitchenaid-washing-machine-parts
Jan 21, 2015 | Whirlpool Washing Machines
My washer cabrio whirlpool do not rinse after wash theres a code F1
Hi, just to let you know - I called 1-800-253-1301 and explained that this is regarding the infamous Cabrio - F1 problem that hundreds of people have complained about all over the internet and apparently is a common problem. The lady (KIM) acknowledged that Whirlpool is having this issue and she immediately scheduled a Service Tech appointment for tomorrow. She confirmed that the service call and any part will be picked up by Whirlpool.
Take care
Jun 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Apr 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops immediately into cycle
f1 is the code for primary control failure cod be a bad connection at the primary control under the control console or a faulty primary control if its still under warranty id have a tech look at it
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
