Question about Samsung Clothes Washer Pump Assembly - DC97-15974C
What model does part DC97-17349B fit? - Samsung Clothes Washer Pump Assembly - DC97-15974C
Hey can a 95 Chevy Tracker Fuel Tank fit on a 02 suzuki grand vitara
what does FIT? mean.
prefect fit, no.
safely fit. no.
can I make it fit , with my welder and metal fab tools, sure.
the 95 is a gen 2 car
the 2002 is generation 5 car, they are radially different bodies
and the 95 is narrow body, with G16 engine.
the 2002 is wide body and mine is 2.5l v6,
You want a gas sucking V6 , sipping from that dinky 1.6L tank?
why>?
my v6 gets 19mpg , best of best.
my 96 gets 28mpg, worlds apart..
not only that the fuel fittings are not the same.
the old 95 uses banjo's
the 95 pump only fits a 95 tank
the 2002 needs a bigger pump. and has different pressure. spec. and flows. and different fittings.
not to mention wrong sender, and all the EVAP and other parts
Feb 21, 2014 | 2002 Suzuki Grand Vitara
How to model real life data?
What is the question?
Put your calculator in STAT mode (2-var statistics or regression )
Enter your data in two lists, preferably sorted according to the x-value
Choose a regression model from the ones available and get the calculator to give you the best fit.
However to see which regression model best fits you data you need a graphing calculator to draw the scatter plot, then superpose on the scatter plot the curve of best fit given by the regression model.
Once you accept a model as the most suited one, you can use the equation of the curve to predict a y-value given an x-value (what ever REAL LIFE meaning they might have)
Dec 11, 2013 | Sentry CA 756 Calculator
Russell hobbs vacuum model no 18213 can't get bags?
You can get Menalux 1900 for Russell hobbs vacuum model no 18213 which fit perfectly. Also you ca buy SENCOR SVC 900 bags which fit perfectly and you get 5bags in one package + filter for very good price.
Also there are moe bags that fit to this vacumm model.
Jan 22, 2012 | Vacuums
Will a Craftsman 42" model 486248392 snow thrower
it shooed fit with no problems but first check the crank shaft
to make sure they are the same size that's always ben the
problem trying to switch motors let me no if you need more
assistance
i hope this helps you
bob
Jun 07, 2011 | Craftsman Garden
Hose broke off fitiing
If fitting on hose broke off, replace hose. If the fitting on pump body broke off it may be a special fitting with a siphon fitting for soap induction which means it may be a model specific part. Start with a model breakdown of parts for your model PW. Honda made motors for a few different PW models and the water pump casing will change with manufactures.
Apr 08, 2011 | Honda Garden
Need user manual for Pacific Fitness model Delmar
Call Inflight fitness @ 1-714-821-4177 the engineer that designed the pacfit units are the owners of this company they may be able help you.
Apr 13, 2010 | Exercise & Fitness
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Samsung Clothes Washer Pump Assembly - DC97-15974C Logo
177 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
