Question about Maytag 24 in. MDBH965AW Built-in Dishwasher
Maytag model # mdbh965aws dishwasher
It wont drain and wont dry! They want $250 just to come look at it!
    Novelist:
  • 101 Answers
The cheap thing to check for first is your pump on the washer. If the pump is clogged up at all the motor won't spin causing the water to not drain. The result is a tub full of water. This can happen just from a coin or a bobby pin getting sucked down into the pump. Tip the machine back and take a look at the pump. You will need to remove it, make sure that you clamp off those two hoses though first with hose clamps, (buy them at any hardware store). Once the pump is off take a look inside and try and move the little motor inside. If it doesn't move easy then something is stuck in there. Just remove the obstruction and put it back on. If that is not the problem then you probably have a problem with your circuit board and that gets expensive. Maytag's have a fuse that burns out and is not replaceable. You have to replace the entire board. But check out the pump first. Most likely that is the problem. If you have any other questions let me know. I am here to help. Good luck.
Posted on Jan 22, 2009
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
MDBH968AWS3 THE AUTOWASH BUTON WILL NOT LIGHT AND IT WONT START
Lemme guess: First only one key failed, but OK, so we just use another setting. Then another key, then all keys but, say, AutoClean, but no Start, right? There is a ribbon cable connecting the keypad to a circuit board that corrodes from moisture, despite being "sealed" in a plastic sandwich. Imagine, moisture inside a dishwasher! As the corrosion progresses, it eventually breaks the connection to each key. Clearly a design flaw--Maytag has replaced this cable twice now (under warranty) in my first year of ownership, yet they continue to replace with the exact same part, and it fails in the exact same place each time.I fully expect this one to fail within six months or less. Only thing left is BBB.
Jun 10, 2010 | Maytag 24 in. MDBH965AW Built-in...
Mdbh965aws noise from motor
sounds like you might have broken glass or some other obstruction i your wash pump you will need to remove motor and clear before it causes to much damage to pump housing let me know how you went
Nov 14, 2009 | Maytag MDBH965AWS Stainless Steel Built-in...
My dishwasher has water going in to it and it drains but it's not making it to the arms, my dishes are still bone dry after all cycles even pre rinse.
it appears ur wash motor is not running.try this-start the unit and let it run for 2 min( this is the water fill period) and after 2 mins u should hear motor running and water splashing sound.u can even open the door and look for water falling from the spray arms.but after 2 mins if u hear only a humming sound and no water splash sound then motor is bad and needs to be chgd.drain motor is seperate for draining the water.
Aug 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
No power indiction lights
yeah! most of the time it is the control panel. but still u want 2 chk the door sws and any burn signs on the control board.
Aug 18, 2009 | Maytag 24 in. MDBH965AW Built-in...
Maytag Dishwasher MDBH965AW No Power
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Maytag Dishwasher MDBH965AW will not power.
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDBH965AW Built-in Dishwasher Logo
248 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
