Question about Bose 901 VI Main / Stereo Speaker
Connecting my equalizer Bose Series VI to Sony HT DDW840
I have tried to connect my equalizer to the "Tape" circuit, but of course it has no effect, because I don't believe this circuit intercepts the amp b efore the volume. Sound Fields are not full, and sound is unlike I am used to hearing from this system. Also first time connection to Digital Audio from Comcast Cable.. Time for a new AMP??
    Brigadier General:
  • 8,546 Answers
The solution is simple and cheaper than you think.
Unfortunately, using the Tape Monitor in a Digital Receiver has its problems. On mine, as soon as you engage the Tape Monitor the digital sources are disconnected. What I did was to buy a separate amp for the 901's and feed the front analog audio out to the EQ which is directly in front of the amp. Besides, the Active EQ is for the 901's only. It doesn't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Posted on Apr 13, 2009
My camera boss 200
Posted on Jan 23, 2009
How can i hook-up a 901 series vi equalizer to a str-de897?
I own 901's(since new) with the active equalizer powered with a non-Sony surround sound receiver.
Basically, you use the MD/Tape in/out jacks to route the signal to the Bose active equalizer. Switch the Tape Monitor switch if no sound is heard.
Here are some references.
https://docs.sony.com/release/STRDE897.pdf http://products.bose.com/pdf/customer_service/owners/901_guide.pdf
Connect equalizer cables (4 total) to the MD/TAPE section of your receiver. OUT from the receiver to the equalizer IN and Out from the equalizer to IN on the receiver.
One issue with the equalizer running through the MD/Tape jacks is that it may affect any other speakers hooked up to your system.
Mar 15, 2016 | Audio Players & Recorders
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
How do i hook my bose 901 equalizer into deno
The Bose EQ connects to the tape out and tape in on the amplifier or reciever. If you were using these for a tape deck, you will then have to connect the tape deck to the tape in and out on the Bose EQ.
Beemer530
Mar 22, 2009 | Bose 901 VI Main / Stereo Speaker
Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Nov 17, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Connecting the 901 series VI equalizer
hello
please make sure your receiver has a tape monitor switch on the front panel or pre-in/out sockets at the rear. only then all sources will play thru the bose equalizer. also remember if you need a 5.1 or greater setup, you will need 2 amps/receivers.
hope this helps
May 27, 2008 | Bose 901 VI Main / Stereo Speaker
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Feb 13, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
293 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
