Question about GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket
I just got a brand new GE Front Loader Washer & Dryer.
Is it normal for a load of laundry to tak 1 hour to wash?
  • 548 Answers
No, but it depends on in part on what cycle you selected. Did you happen to choose one with an extra rinse cycle?
Posted on Feb 06, 2009
I have an ariston awd 121 front loader washer dryer. What kind of soap does it call for? Can it be the powder? Does it have to be liquid? Does it have to be a certain brand/type?
To my knowledge all front loading washers require low sudsing high efficiency (he) detergent and these only come in liquid. A powdered detergent could probably be used, but I'd try a 1/4 of the recommended amount for a normal load first. Also it is not recommended. Regular liquid detergent can also probably be used but i'd start with 1/2 the the amount for a normal load. If you don't use the recommended "he detergents" expect occasional oversudsing problems and possibly even early drain pump death. Hope this helps.
Here is the owner's manual for your machine:
http://www.managemylife.com/mmh/owner_manuals/25710/ARISTON-Laundry-Centers-L0520687
Jan 12, 2013 | Ariston Technologies Ariston AWD12 Front...
Tip
New detergent Sheets are NOT a good idea for front load washers
In the last week i have went to many customers home to remove detergent sheets from washing machine pumps on front load washers.
Purex® Complete 3-in-1™ Laundry Sheets are now on my "DONT USE THIS PRODUCT LIST." As an appliance repairman, i have made lots of money removing these sheets from the drain pumps on front load washing machines. I was at one of those jobs today and the customer watched me pull 14 of these sheets out of the pump and up into the hose that leads to the pump. I tested the machine and it then worked fine.
About 1 hour later, the customer called me and was furious because as she was doing a load a laundry and the water would no drain out again. I went right back to her home and once again i found more of those sheets inside her pump, 5 to be precise. About an hour later, i was done doing a complete clean out of her washer to make sure this didnt happen again.
She will no longer use Purex® Complete 3-in-1™ Laundry Sheets per my recommendation.
The sheets were designed to keep you from wasting money on using too much soap with the added ease of it also being a fabric softner sheet. Dont be lazy and dont use these sheets in a front loader of any brand.
The problem is that small articles of clothing like baby socks, and these sheets, make it thru the front seal and make its way between the tubs and on to the pump. This does not seem to be a problem with top loading washers yet, but we will find out in the near future.
Levi Holiday
www.lartoday.com
on Dec 09, 2009 | Washing Machines
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
My GE spacemaker top loader will not drain, makes buzzing noise
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
Front-load washer doesn't clean!
I don't know anyone who thinks the front loader is better except for stacking things on top of...
Certainly the performance of the modern water-saving front-loader is questionable when compared to earlier models - which is why I think a wash takes much longer these days with a modern machine, I think it has to in order to be effective. My friend's new front loader can take a couple of hours to complete a programme and it is only a washer and not a waser/drier.
The older washers used to take everything that could be pushed inside and the laundry would emerge smiling. These days overloading is a complete taboo and should be weighed to ensure nothing is strained.
Your washer might have a fault but in the final analysis you made a contract with a retailer to, in return for a consideration, supply you with a washer to clean your laundry. The supplied washer doesn't clean the laundry in spite of your best efforts and that means the retailer has broken the contract. It is up to him to sort matters out to your satisfaction.
Mar 25, 2017 | LG WM2016C
Stinky clothes
you should run a empty load with bleach but no detergent every month or so to clean the washer, I also recommend cleaning the boot (door gasket) every couple of loads with windex or other cleaner. also every load check inside the bottom of the boot and make sure the drain holes (x3) are clear of lint, etc. this is normal maintenance for any front loader. GE is a very good brand and is my preferred brand, I repair appliances everyday, Whirlpool keeps me busy. I have GE front loaders in my house.
2nd poster, you will need a door hinge for this most likely. Not too hard.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
GE Front loader
My washer has the same issue. I am also looking for a manual.
SK
Mar 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Shaking like crazy
ALERT. transit brackets still on machine ..REMOVE THEM;;
Nov 25, 2007 | GE WBVH6240F Front Load Washer
GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket Logo
142 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
