Question about Ezip The E-450 Scooter
Ezip 450 scooter not running
Charged but will not run
I have a 1993 arctic cat 700 efi that the battery keeps going dead in how do I check if its charging?
When a battery dies while the engine is running it is not being charged. When the charger is working the engine will run without a battery
Dec 13, 2014 | ATVs
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
Battery won't charge the wheel that runs the belt won't work
It sounds as though you may have run down the battery because the alternator was not charging. You'll need to check the belt and fix whatever is keeping the alternator from turning, then get a jump start, or charge the battery. After starting, check the voltage to be certain the charging system is working. I hope this helps.
Mar 31, 2014 | 2006 Kia Sorento
Gx75 not charging
a lawn mower battery is only good for a couple years when keeping it charged and testing voltage doesn't tell you what is has for amps is the volt meter read more than the off voltage while running then it works they only have a 4-7 amp charging system
Apr 30, 2012 | Garden
Why does my battery loosing its charge ? I charge it but it keeps running down ? I have checked every thing that I think could be a problem
How old is your battery?
Is your battery being charged when the engine is running?
Have access to a 12 volt dc voltmeter?
Put across pos. and neg. side of battery while engine is running should read ABOVE 12 volts dc?
then check voltage when engine is off and compare?
if you have a higher reading when the engines is running than when engine is off then your charging system is charging, Then battery is suspect.
if it is not charging or no difference in voltage when engine is running or isnt running then look into the engines charging system IE: charging diode,good and clean ground wire connections, etc: without knowing more detail this is a basic check.
Note :Run your engine at higher than idle when doing these checks
Jan 16, 2011 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Worked fine, next time would not run at all. 1.5 years old. Light showes charging and charged OK
mcdevito75 here, It"s possible, an Old battery would show a full charge and still not be fully charged or even charged enough to run the shaver, try changeing the battery--ies.
Jun 30, 2010 | Health & Beauty
Battery will not stay charged ,bought new one i started motor & disconected battrey, motor kept running ,what keeps battrey charged ?
If your charging system is working, you can disconnect the battery while it's running, and it will stay running. The stator assembly (Like a car alternator) will supply the current to keep the bike running along with charging the battery. A multi-meter should show around 12.5 volts at the battery with the engine off, and just under 14 volts running, under normal working conditions.
Jul 07, 2009 | 2002 Yamaha XVS 1100 Dragstar Classic
750 gxxr will not stay charged
the voltage regulator/diodes is not working, stator wiring loose or fuse blown from reverse polarity
use a voltmeter to check if is charging
not run voltage to run voltage
NOTE full charged battery is 12.6v
would need min. 13.5v when running
or
disconect battery after is stated to see if runs?
if keeps running is OK
if not then check charging system.
if runs an still stalls when placed in gear?
trouble with kickstand safety switch
Jun 21, 2009 | 1997 Suzuki GSX-R 750 V
Ezip The E-450 Scooter Logo
80 people viewed this question
Top Ezip Cycling Experts
Paul Bade
aldwin weng
aldwin weng
Jason Larocque
Jason Larocque
Are you an Ezip Cycling Expert? Answer questions, earn points and help others
