Question about Hitachi 53SDX01B 53" Rear Projection Television
Dark screen on hitachi 53sdx01b
Picture is dark even after trying all video and focus adjustments. Picture is only dimly visible in a dark room perpendicular to the screen, not at an angle.
  • 163 Answers
SOURCE: TV has dim picture
well excuse me but if you got the esquematic lets analyse this problem, first we got signal(you can see the picture) if got picture the sound signal is there (they tavel both the same way audio in a sub)then we got swept both vertical & horizontal (you see the picture) what we dont have? asignal amp,(thats the snow) good control of the 3 canyon so thats a comun problem for all 3 canyon, then we have to check for voltage reading in video amplifire it are not working ok and check for a leak capacitor in coupling circuit in the amp circuit what else ? did I over pass something? hope help you ...good luck... post back
Posted on Aug 08, 2006
premtech
  • 934 Answers
SOURCE: Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Posted on Jun 04, 2007
ctf1800
  • 4402 Answers
SOURCE: shadow around objects in picture...shadow is bluish
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
ctf1800
  • 4402 Answers
SOURCE: HITACHI ultrascan hd tv....
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Mar 03, 2008
  • 80 Answers
SOURCE: TV red spot
Your light engine is going bad.
Posted on May 21, 2009
Vertical position does not work on remote. Magic focus on green goes half way stops then number five comes on screen. Hitachi 51inch rear projection tv
Magic focus on a Hitachi only adjusts at 16 points on the screen and needs to be done in a dimly lit room. Frankly its a sales gimmick, the number 5 means one of the sensors inside the screen for the Magic focus is not connected or bad.
Go into the tech mode for convergence with the original remote (that menu is called the Decam mode) and see if convergence will adjust there. There are close to 120 points that can be adjusted there as opposed to less than twenty in the magic focus mode.
Dec 23, 2012 | Televison & Video
Picture quality is very dark.
Well, that explains a lot----mirror or the lens or even the screen may be coated with grime-----be careful if you attempt to clean that screen, easy to damage and expensive to replace--what about the mirror and the 3 lens?
Dec 04, 2012 | Hitachi 53SDX01B 53" Rear Projection...
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
Mar 21, 2012 | Hitachi 53SDX01B 53" Rear Projection...
I have an Hitachi 53sdx01B rear projection HD TV. Worked great until yesterday when it seemed like the contrast or brightness got out of whack. Whites appear to be overly bright, to the point that...
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
Feb 05, 2011 | Hitachi 53SDX01B 53" Rear Projection...
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
Picture is dark with a lot of red
Try adjusting your screen drves to tubes, you have a Focus/screen drive contol block that adjusts each Tube R/G/B, you could also have poor solder connection or leaky capacitors causeing Dark Picture.
Mar 24, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Dark background blue tint
Try the Magic Focus option on the menu screen found under "Picture". Make sure the TV is on for 20 minutes before activating this option. It is also best to run this when the room is dark.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 53SDX01B 53" Rear Projection Television Logo
22 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
