Question about KitchenAid (KSBP23IN) Side by Side Refrigerator
Kitchenaid Refrigerator Water Dispenser
No water comes out of the dispenser when the lever is pushed. It does make a noise when pushed.
  • 72 Answers
Bad solenoid assembly
Posted on Jul 11, 2007
SOURCE:
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
There is no water coming out of the water dispenser. I changed the filter and check the water line coming from the pipe, there is water coming thru the water line. when I push the water dispenser lever I...
Well, there is no "motor" for the water dispenser, only a solenoid valve. However, there could still be a problem with the solenoid even if you do hear it when its energized. Hearing it make a noise does not mean its working properly.
Aug 13, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Water Dispenser not working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Delay in water dispenser
If you get us a Model # it would help FIXYA Folks help with some suggestions.
Should be Inside the refrigerator, on the left wall. silver sticker. Thanks
Feb 27, 2018 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser lever (where you push the cup in) has popped out
I made the repairs by the seat of my pants and --yes, it's all fixed now. It sure would've been easier if I could've removed the face plate to the control panel to get access to the problem underneath. I hope I solved your other user's problem with the water dispenser.
Larry
Apr 05, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser does not work
The lines are likely clogged and will need to be removed and cleaned. Otherwise, although the pump starts, the valve may be clogged or non-functional.
Feb 11, 2018 | KitchenAid KSSS36QK Side by Side...
Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenses without pushing lever
There is a solinoid valve that opens when you push the switch in. It has apparently failed and is leaking. Sometimes taking it apart and cleaning it will fix the problem.
Jan 28, 2008 | Kenmore 53542 / 53544 Side by Side...
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid (KSBP23IN) Side by Side Refrigerator Logo
165 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
