Question about Refrigerators
FrigidLights on in freezer, off in fridge. Compreaire FSC23F7DSB8
I needed to pull my fridge out to do some cleaning behind the fridge. I unplugged it, then plugged it in again 5 minutes later. The lights are now working on the left side of the unit (freezer) but not on the right side. The compressor is no longer working and the temp display is off. I`ve tried pressing the reset button, with no success
  • makaskel Jan 22, 2009
    This is a Frigidaire FSC23F7DSB
  • 410 Answers
Did you clean the compressor compartment while you had it pulled out? its possible you pulled a wiring harness loose removing power from the fresh food side of the refrig and from the comp.
Posted on Jan 22, 2009
Freezer is working,but fridge is warm. Fan in back of fridge will not shut off.
If your fridge is not designed with an automatic de-icing function, then there may be an ice dam blocking the cold air from moving from the freezer to the fridge. I had a fridge once that would get blocked with ice even if the rest of the freezer was ice-free.
Unplug your unit (often shutting off the breaker is easier than digging behind the fridge for the plug).
Pull everything out of the freezer and put it in a box. Cover the box completely with blankets to insulate it so your food doesn't thaw and spoil. Prop open the freezer door and let any ice accumulation melt.
Once everything has thawed out, wipe up the water and plug the unit back in. You should be able to tell after 10 minutes or so whether the fridge is getting cooler or not.
Mar 04, 2015 | Refrigerators
GE profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. Pulled back panel cleaned the condenser fins with compressed air andchecked the connections. runs fine but can'
I had this happen with my fridge when the door was open for awhile when I was cleaning the inside. I did what you did, clean everything behind it. Pay particular attention to the circuit boards, there may be reset buttons in that area. Then unplug the freezer for 10 minutes (make sure it's for a FULL 10 minutes) then plug it back in and try it.
Feb 03, 2015 | GE Refrigerators
Fridge not cooling
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 10, 2012 | Refrigerators
You say clean outside coils and fan motor coils. Where are they?
The "outside" coils that you are looking for on a refrigerator will be found either on the back, or in the case of your Amana, on the bottom - behind the toe space bezel. There are no coils on the back of the fridge.
The coils are usually thin, black grates that contain the refrigerant. Be careful not to damage them when cleaning. Open the freezer door (yours is a bottom freezer type) and simply grasp at the top of the bezel an gently pull away from the frame.
Use a narrow crevice vacuum tool attachment to pull the dust and debris from the coils. Use a flashlight to see beyond the very front. You may also wish to unplug the fridge so that you do not damage the fan if it is struck by the tool while running. You should vac the coils annually or more frequently if the fridge is in a dusty area - or there is a lot of pet hair collecting on the coils. Some fridges also have the fan hidden behind a removable panel on the at the bottom of the back side of the fridge. If cleaning fan blades - you must unplug the fridge before attempting. Vacuum any dirt and dust on visible coils seen near the fan.
Mar 29, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Casing between fridge and freezer getting very hot
the condenser motor is hung up or has went out ,,, pull fridge from wall and set a fan behind the fridge to blow on system till you can replace the motor / thanks
Jul 07, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water under veg bins
Hi. thanks for the question . the problem you have is with the drain tube, from under the freezer wall ,in the fridge. that tube is clogged up . pull fridge away from wall. locate the drain hose at the drain tray. clean. also clean all coils behind fridge thanks the appliance doc
Sep 30, 2008 | Kenmore 20.6 cu. ft. Top Freezer...
Frost free fridge freezer freezing up fridge not cooling
make sure that the vents between the freezer and box are not frozen..check to see if the fan in the freezer is working(evaporator fan)..check timer and defrost heater,,
Aug 18, 2008 | Refrigerators
Fridge and freezer too warm after cleaning
I guess by now you have resolved this.. If you need help please alert me..
If this is unresolved, can you tell me if the compressor runs? According to the Jen air manual I downloaded, you shud be able hear a number of sounds from the fridge, at different stages eg defrost, cooling etc. Obviously you checked the temperature controlls? Door seals Ok? Power,is the light on.. Even if there appears to be power, pls change the power outlet and run the fridge from a different source. Pls advise if you still have problems. Rgds,
May 01, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
