Question about Whirlpool RBD305PD Electric Double Oven
Having trouble with the clock display
After a power outage, my clock will not stay on display. It will come on when I push the clock button, I get the time and "start?" displayed underneath the time. How do I get the clock to stay on all of the time?
  • Anonymous Mar 17, 2014
    After changing the time on my clock, it disappeared and the screen is dark. It shows up for seconds if I touch the clock button.
  • 54 Answers
Try holding down clock button.. when you 1st hold it down it will appear.. keep holding til it disappear.. then when it comes back on let go of button.. if clock button don't try another like + or - sign.. good luck.. mike
Posted on Jan 23, 2009
  • aimee_stead
    aimee_stead Oct 03, 2012
    SO excited!!! It worked! Thank you!
Why won't the clock stay lit? Shows the correct time, but only stays on for a few seconds.
Some clocks work that way. I guess they're just saving power.
Hope this helps.
Feb 24, 2015 | Ovens
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
Built-in oven-- clock unresponsive
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
We're having trouble setting the clock on our Kitchen Aid Superba double covenction oven. When we push "clock set/start" and enter the time, and then push the "clock set/start" again,...
go to www.searspartsdirect.com. You can get a manual from them or you can go to www.whirlpool.com and possibly download one from there, make sure you have your model number with you.
Mar 13, 2011 | Ovens
Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
My step Dad's whirlpool, electric, self cleaning oven will not heat up at all. Model # RBS245PD012. The power went out for just a few minutes so he was resetting the clock. An error code E3-F1 is on...
Hey there-
He ended up calling a repair tech.. He came out and ended up replacing the whole control panel.
My step Dad says it works fine now and the clock is a lot brighter on the display than it was before, so maybe it was slowly going out then finally just gave in. ?? Thanks for checking in though.
Oct 06, 2008 | Whirlpool RBS245PD Electric Single Oven
Fridgidaire Electric Oven Clock
try holding the clock pad/button in for 3-5 secs it sould beep and remain on . youve turned the display off. that should reset it. if not give a call to the manufacture. they get a lot of these calls when time changes back/ahead
Mar 12, 2008 | Ovens
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool RBD305PD Electric Double Oven Logo
426 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
