Question about Plumbing
My uberhaus vanessa kitchen faucet pull out hose sprang a leak. The replacement hose seems to have a different size fitting than the original from 2 years ago. Has anybody had a similar problem?
The original end fitting seems to be smaller
  • 62 Answers
SOURCE: DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
Posted on Jun 05, 2009
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
SOURCE: I am reinstalling a Moen 7345 riser faucet in my
I had a similar problem and, like you, found that there was nothing for the washer to seat against. Apparently, there was a metal bushing installed when manufactured, that was entirely eaten away by electrolytic corrosion - mine took nearly twenty years. I machined a new non-metallic bushing, installed it, and the problem was solved.
I also sent Moen's president a letter explaining the problem and how to fix it but heard nothing back from them. At the time, no parts were offered that could fix the problem.
Posted on Mar 23, 2010
packrat1948
  • 528 Answers
SOURCE: I have a 3 years
moen hoses seem to hold up better then just about all of them out there.
Posted on Feb 16, 2011
packrat1948
  • 528 Answers
SOURCE: I have a single handle
Using the number you gave it is an American Standard faucet here is a link to a parts place.
I would use the factory parts.
http://americanstandard.faucetdirect.com/index.cfm?page=product:partsDisplay&productId=4205.104&manufacturer=American%20Standard
Posted on Mar 09, 2011
Copper piping? Tub faucets
1. Measure piping size with tape measure or read printed on pipe. 2. Visit local hardware store and take the faucet. 3. Tell them you need a tubing cutter and sharkbite adapters for the faucet you have. 4. Cut pipe with tubing cutters. 5. Push on sharkbite fittings. 6. Install faucet and supply hoses. 7. Take Bath.
Apr 28, 2013 | Plumbing
Replacing pull out hose on kitchen faucet
get a hole saw that fits a drill. they come in all sorts of sizes
Jul 16, 2012 | Danze Plumbing
Grohe ladylux plus kitchen faucet leaks from multiple points along metal pull out hose attached to faucet head. Is this fixed by replacement of same hose? How do I replace the hose?
Feb 23, 2010 | Grohe Plumbing
Flexible hose under sink leaks at natural bend; can it alone be replaced ?
Most are 3/8 hose if you can take it off most supply houses should have them. Or check lowes or howe depot. Just take it with you to match length and pipe size up.
Feb 12, 2010 | Price Pfister 532-7PCC Marielle Pull-Out...
I have a new hose for my Grohe Euro Plus to replace a leaking old one. I have disconnected it from the water supply but now the ends of the the old hose will not fit through part connected to the sink...
There are 2 sets of nuts and washers underneath the faucet that holds the faucet in place. loosen them and the water lines (after turning the water off) faucet lifts off from the top of the sink. Replacement the the same, just in reverse. BE SURE TO USE TEFLON TAPE OR PLUMBERS PUTTY ON THE WATER LINE THREADS TO PREVENT COSTLY LEAKS.
Jun 20, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
I set up a drip system years ago and now am looking to replace it (old, worn, leaks) but the problem is this-I can't push any fitting (be it connectors, tees, etc) onto the main hose. Both hose and...
It's not really a solution-it seems there are two sizes OD (.700", .620") both called 1/2" tubing. The appropriate sized fittings must therefore be used
Mar 21, 2009 | Raindrip R333CT Swivel Tee Adapter
Plumbing Logo
520 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
