Question about Tablets & eReaders
Busbi tablet won t load just keeps showing robot on screen how do in reset tablet
3 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 17, 2011
  • 5 Answers
SOURCE: tablet crashed won't do anything
coby has recently had major tablet problems,call manufacturer.send 15.00 money order.
Posted on Jul 22, 2012
II have a keep tablet,its stuck on the main logo screen,I did the reset already now its stuck
Hi Anonymous, The link below is a youtube video showing you how to fix your tablet, There's video's down the right side you can check out as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 18, 2016 | Tablets & eReaders
My tablet wont come on. whenever i turn it on it just comes to the loading screen and says system loading. then it wont go any further its stuck on the loading screen. what's wrong it?
Sounds like a previous update did not finish installing due to being switched off in mid stream or it got corrupted.good news is you can reset android tablets to factory settings...bad news is you will lose all you settings and apps which you will need to reinstall once it is up and running.most tablets reset in the same way.
switch off ...then whilst holding the up volume and the home button hold down the power button then continue holding just the vol up and home button.it will display the robot then you can let go of all the keys and follow on screen instructions to reinstall factory reset.
some tablets are a little bit different to reset...instead of volume up its volume down.if you google your make and model of tablet it will describe correct procedure...one last thing...do not panic if it doesn't reset first time...some Chinese based tablets may take two or three attempts to reset.
Jun 11, 2015 | Tablets & eReaders
How Do I Reset an Idolian Studio 10 Tablet that is looping on the Android logo?
The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
Jan 26, 2015 | Idolian 10.1" Android 4.1 Jelly Bean OS...
Reset zeki tablet
if all you see is a large green android robot then you will have to reflash the tablet as android is having a problem booting up
http://zekitablet.com/support.html
there are too many models to give you specific instructions need to know the model number
Sep 06, 2014 | Tablets & eReaders
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Apr 17, 2014 | Tablets & eReaders
Keeps constantly restarting
Warning: All applications and personal files contained on the tablet will be erased. Only do this if you are unable to start your tablet.
  1. First, ensure the tablet has been switched off.
  2. Hold both the VOL+ and POWER buttons until the Gemini logo appears. Release both buttons.
  3. You should see a green robot on the screen with a red warning sign.
  4. Press & hold POWER then press VOL+ once, then release the POWER button. A menu will show on-screen.
  5. Using the VOL+ and VOL- keys you can move up and down to select the Factory reset option. Press POWER to select this option, then move down to YES and press POWER again.
  6. Once completed, press POWER to restart the unit.
Apr 13, 2014 | Tablets & eReaders
Zeepad does not open
can't get netflex to show picture.
Dec 29, 2013 | ZEEPAD VIA8650 Android 2.3 Tablet
My tablet keeps on going back to the loading screen and repeats that
You will need to reset the machine to factory settings by holding in the "Reset" button with the power on. Then just wait until it reboots. If this doesn't work you may need to get the Operating System re-installed.
Feb 18, 2013 | Irulu Black 7 Inch 2gb Mid Google Android...
Busbi 7 wont load just stays on android robot screen
Problem solved! The support at Busbi actually turned out to be quite responsive. Reply as follows:
Thank you for contacting support, sorry to hear you are experiencing issues with your tablet.
Can you please try a factory reset on the device, Connect the USB lead to the tablet and your computer please leave for 10 minutes remove the cable power down the unit if the unit powered up, press and hold volume + also power keep held until you see the bees, release both keys.
Use volume - navigate down to wipe data / factory reset
Press power
Use volume - navigate down to yes -- delete all user data
Press power
After formatting system will be back at the menu
Press power to reboot system now.
Jan 25, 2013 | Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Tablets & eReaders Logo
310 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
