Question about Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit
Toshiba e-studio 4520c ce20 error - Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit
2 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: toshiba e-studio 350 error ce20
ce 20system management module access abnormality
Posted on Aug 15, 2010
How do i get rid of blank lines in copies on my Toshiba studio 3530c
Make sure the toner waste container is empty and also the charger and glass cleaner brushes are pulled out and put back to ensure these are clean. See maintenance actions in this guide. http://www.eid.toshiba.com.au/customers/c_es4520c/manuals/pdf/Mash/OM/Quick%20Start%20Guide.pdf
Sep 12, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
Error c970
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Apr 22, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
Toshiba 2820c service manuall
http://www.smpcshop.com/Toshiba-e-STUDIO-2020C-2330C-2820C-2830C-3520C-3530C-4520C-Service-Manual.html
Sep 28, 2013 | Office Equipment & Supplies
Faint lines
Try replacing the roller, or maybe you moved it and is not in place- in the exact position.
Jun 29, 2012 | Toshiba E Studio 3520c 3530c 4520c Copier...
Error ce20
Hi how are you this is jack ... jack_pak@hotmail.com
Dear follow the procedure...
[CE20] Image quality sensor abnormality (no pattern level)
1. Check if the transfer belt or transfer belt unit are securely installed.
2. Check for any abnormal stain caused by poor cleaning, large flaw or break on the transfer belt
surface.
3. Check if the drum and the transfer belt are rotating. If any abnormality is found, correct any
mechanical problem.
Is the connectors CN345 on the LGC board disconnected?
Is the connector of the image quality sensor disconnected or the surface of the sensor stained?
Is the harness between the LGC board and the image quality sensor open-circuited?
Is the shutter of image quality sensor opening and closing normally? Is the shutter damaged?
PLEASE VOTE ME.
Thanks,
Best Regards,
Mar 29, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 350 error ce20
Mar 28, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit Logo
356 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
