Question about GE 30 in. Profile JP938SCSS Electric Cooktop
Ge cooktop f142 code - GE 30 in. Profile JP938SCSS Electric Cooktop
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
Ge monogram cooktop model#zeu30rsf1ss error code f1 74
Hi There
I have found the codes that you need and hope this helps you.
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.Thank You for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | GE Monogram ZEU30R Electric Cooktop
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Fault Code
today F116 began flashing...what to do..its only 2 yrs old.
May 26, 2008 | GE 36 in. Profile JP969 Electric Cooktop
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
GE 30 in. Profile JP938SCSS Electric Cooktop Logo
142 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
