Home | LG | (8 GB) Digital Media Player (MFJM53) | Problems with LG MP3 Pla...
LG Digital Media Player
Problem for LG (8 GB) Digital Media Player (MFJM53)
Problems with LG MP3 Player (due to a mistake in the operation of the device)
By jennyr on Jul 03, 2007
Hi all:
I have a problem with my LG MP3 Player recently adquired.
By mistake I accidentally deleted a set of files, after that, my player didn't work anymore.
I was looking into LG web site the support to solve this problem, and actually I found a set of files to "upgrade" the player.
I applied the procedure to upgrade it, and now the Player is working fine (with all functionalities: Video, Music, Radio, Photos, etc)
But on despite of that, I'm still have a problem every time I turn on the device, the error message is the following: Not initial file download FM37.INT.
I NEED YOUR SUPPORT TO LET ME KNOW HOW I COULD GET THE FILE NAMED FM37.INT THAT THE PLAYER IS ASKING AND IN ADDITION TO THAT WHERE DO I HAVE TO COPY (INTO THE PLAYER).
For your information that was the sequence of errors that I have received after I made my mistake:
1st Error:
Not initial file download FM37.INT,
2nd Error:
VIS loading failing
3rd Error:
Font Loading Error Q02
Then I downloaded the zip file with the upgradeable version (sorry I did not find which version I downloaded) and now I just receive this message I mentioned (every time I turn on the device):
My MP3 has the following features:
LG FM37 (Touch Me) and Firmware Ver. S1.10EN
Thanks in advanced for your support
Same Problem
Mar 09, 2009
-   I have a 2 GB UP3 Player model UP-S... It's also branded with LGT-UP-S(B) on the back sticker. I reformatted the device while using it as a USB drive and killed the MP3 player as I had no idea the software to run the device was actually stored in a way where I could destroy it.
I've poured over LG's site and have not found a single it of support docs for the device much less something along the lines of a firmware upgrade.
I tried their chat and they told me that I've basically turned my mp3 player into a USB key...
I can't find the firmware anywhere online. -   Guest
Feb 18, 2009
-   tengo el mismo problema con mi lg fm37 error q02
-   Guest
Feb 16, 2009
-   NO INITIAL FILE-   andresca777
Jan 04, 2009
-   my LG Prada ek850 not playing any mp3 anymore -   zeenbeen1234
Jan 04, 2009
-   Mp3 not playing i dont know why  -   zeenbeen1234
Best Solution
posted on Mar 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi, everybody
I had the same problem, and i found this page.
Just, there is a problem, who knows chinisse jejejejej
if any body sould traslate this wold be helpfull.
http://www.coolnstyle.com/DownloadDetailCmd.laf
Solution #2
posted on Feb 05, 2008
Very Helpful)
Robochubby
Rank: Apprentice
Rating: 96%, 15 votes
I too have had the "Device Manager code 9001 see manual" message come up on my LG unit, after having upgraded the firmware. All my music and photos disappeared and the unit would lock up if I tried to record anything.
I decided to format the device (from the General Settings) and the error message doesn't come up anymore. All my stuff was gone so there was nothing left to lose. It seems to be working now. I hope this helps you guys too.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on May 31, 2008
Helpful)
vumba
Rank: Apprentice
Rating: 93%, 4 votes
My media center diskette freezes when I run it. Can I download the software?
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Jan 03, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Buy a brand new LG MP3 Player. I have the same problem
Solution #5
posted on Mar 13, 2009
Very Helpful)
chelisillo21
Rank: Apprentice
Rating: 100%, 2 votes
hola chicos no hablo ingles pero creo que esta informacion les puede servir, yo tambien tuve problemas con mi reproductor lg FM37 (MF-FM37F2S, segun etiqueta trasera) me enviaba los mismos errores que a jennyr, o sea Font Loading Error Q02, bueno me di a la tarea de investgar y he aqui la solucion, busquen el programa "LG Media Center" en cualquier centro de descarga de freeware (apoyense con el google), una vez logrado esto lo instalan en su equipo, busquen en la pagina de LG el manual de usuario, en el se detalla la informacion de como actualizar el firmware de su mp3 y es sencillisimo, solo que antes deberan formatear el mp3 utilizando el explorador de windows, lo desconectan, abren el LG Media Centr y lo conectan de nuevo al pc, y automaticamente el programa de LG Media Center lo detecta y detecta el firmware actual, les va a decir si desean actualizarlo y listo, sigan las instrucciones que en el programa se detallan.
nota: cuando vallan a instalar el formware en el reproductor es posible que les mande el mismo error que al principio y no se qiera instalar , bueno solo reseteen su reproductor utilizando un clip y lo vuelven a encender y listo comenzara el update.
importantisimo: dejen por lo menos unas 8 horas el reproductor conectado a la pc para que se cargue bien y eviten que se les descargue por completo.
Was this helpful?
Yes
No
Solution #6
posted on May 25, 2009
Not Rated)
hatfix
Rank: Apprentice
Rating: 0%, 0 votes
I also did a firmware upgrade and found everything gone! Lots of error messages.
However, a simple fix is to go to settings and format the device.
This will wipe all your files (they are probably gone anyway) and maybe you will need to set up new folders also (go to My Computer, open the LG device and set up new folders if needed.)
Download the files (music, photos etc) again.
PS if anyone has had success loading video files on an LG FM37 let me know. The LG media centre and the device don't seem to recognise any video formats.
Bob
Was this helpful?
Yes
No
Solution #7
posted on Feb 03, 2009
Not Rated)
olgutza26
Rank: Apprentice
Rating: 0%, 0 votes
Guys NEVER upgrate the firmewall . It's a bad thing. I had the same problem and Robohobby helped me. Thank yo very much!!!
Was this helpful?
Yes
No
Solution #8
posted on Dec 04, 2008
Not Rated)
mario_fuma
Rank: Apprentice
Rating: 0%, 0 votes
como ormatear fm37
Was this helpful?
Yes
No
Solution #9
posted on Nov 07, 2008
Not Rated)
teejayrock
Rank: Apprentice
Rating: 0%, 0 votes
i got a lg jm53 but when i come to download information via the media player it just crashes.
i have also tried to download it via Window media player same result.
I tried downloading using my computer and transferring files but my computer wont let me transfer to it ,saying i can only transfer to my E drive , but it not on there.
Any help guys.
Was this helpful?
Yes
No
Solution #10
posted on Oct 08, 2008
Not Rated)
thaifan1
Rank: Apprentice
Rating: 100%, 1 votes
For those FM37 Mp3 multimedia player owners who thought the radio was rubbish, because it couldn't pick up any stations, - there is a simple solution.
In "Settings" for radio, you may find that under the subheading "Regions", the setting may be "Other". That is, for regions *other than Japan or Korea.
Though I am in Australia, I changed it to "Japan", and can now listen to good reception.
So, wherever you may be, if not Japan or Korea, try one of those 2 choices, if intial reception is non existant.
I think it all has to do with frequencies.
You can also choose the sensitivity of the radio.
Was this helpful?
Yes
No
Solution #11
posted on Aug 21, 2008
Not Rated)
shortys
Rank: Apprentice
Rating: 100%, 3 votes
how can upgrade my lg cm50016
Was this helpful?
Yes
No
Solution #12
posted on Jul 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i fixed it cunts
just plug it in to computer and then press reformat.
It erases all past data and now works perfectly
Solution #13
posted on Jul 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi me too getting the same messages on my lg touch me ask lg for help but they were as much use as a choc fireguard
Popular Solutions for LG Digital Media Player
Questions and Unsolved Problems for LG Digital Media Player
Do you recommend LG (8 GB) Digital Media Player (MFJM53)?
Answer
Answer
i have lg fm37 4gb and i don't know how to see video?
Answer
the screen display this message font loading error q02
Answer
LG FM 37, Screen displays 'Device manager, Code 002 ERROR FONT, see the manual' on LG MP3 Model:... (More)
Answer
I have a LG MP3 player FM37 4gb which continually says Front loading error Q02 when turned on &... (More)
Answer
Everything functioning fine but new files cannot be transfered to player although there is 1G left... (More)
20 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 29, 2008
exacltly the same problem.. i'm so agry.. i thing i'll by an i-pod..
Comment by Guest, posted on Dec 11, 2008
you know where i can find a firmware for jm53 or jm52 ?
thnks.
Comment by shubham tinu, posted on Dec 01, 2008
My LG TOUCH ME FM37 becomes dead when i'm updating its firmware for mp3 player from internet, suddenly breakup in my network connection and updating was unsuccesful and it stop working from that time.
Please help me.
Shubham Choudhary
11-A, D.D.A. MIG Flats, G.T.B. Enclave, Delhi-110093
Comment by Guest, posted on Nov 28, 2008
YES
Comment by Guest, posted on Oct 09, 2008
LO PRENDO Y ME APARESE FONT LOADING ERROR QO2
Comment by goozz, posted on Aug 22, 2008
I have upgraded the firmware to 2.20 ver. The touchscreen not working well, cannot access to the music folder, video folder, setting folder.
Try to format a few times already, reset a few times, but the problems still same.
Please help me.
Can I get back version 1.10 instead?
Comment by Guest, posted on Aug 20, 2008
ERROR Q02
Comment by nemesis007, posted on Jun 08, 2008
error q02
Comment by Guest, posted on Feb 12, 2008
fm37.int
Comment by Justkunju, posted on Jan 25, 2008
I am also facing the same problem when I switch on my LG MP3 player.These are the errors showing when I switch on the player:
1st Error:
2nd Error:
VIS loading failing
3rd Error:
Is there any solution for this, Pls Advice.
Comment by hungnm, posted on Jan 15, 2008
I have the MP3 Player FM37. After Upgrade Firmware to Ver.2.2 via LG Media Center, it does not work. Each time when power on, a text "! Device Manager code 9001 see manual". But I can't find how to fix this in the manual. Please help me
Comment by Guest, posted on Dec 28, 2007
I have the sane problem!!! Where can i find this file : FM37.INT????
Comment by doonyjnr, posted on Dec 14, 2007
I have pretty much the same problem with my jm53 8gig mp4 player. surely someone out there knows the solution. I also downloaded the firmware from the lg website but to no avail
Comment by risos, posted on Nov 29, 2007
the same problem with my lg mp3 player
Comment by georgemc, posted on Nov 20, 2007
i've got the sama problem!!!!please help me!!!!!
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG Digital Media Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
