Question about Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 scanner (this is NOT the 'cover open' problem)
My problem is that when i plug in the printer, the scanner begins to make this ticking sound. the 'lens' tends to move to the left but it does not stop and it begins making that ticking sound. what could that be? how can i fix it? thanks in advanced.
  • ario_n_angie Jan 22, 2009
    well. mine does not let me use the scanner or copy mode at all.
    Sergeant:
    Champion:
  • 259 Answers
This happens with some printers scanners the are calibrating and then are ready to do work
Posted on Jan 22, 2009
I bought a x3470 printer second hand. It wont respond when i press buttons on printer. It says door open in display window.
Here is a great article on how to try to resolve the cover open error on the Lexmark X3470. http://bit.ly/aoOtEP
Feb 27, 2010 | Lexmark X3470 All-In-One InkJet Printer
Tip
Printer Lexmark x3470 showing "Cover open" / "Cub abierta" while closed,...
Hi
This is a common fail in this model. there is a white plastic arm which works as an extender for the switch that senses if the cover is open or closed. This part is easily detached from its place (in my case not broken but it could happen I suppose) resulting in printer showing the message "Cover open" / "Cub abierta". the switch is situated under the scanner in the middle . when you lift the scanner part to see the ink cartridge, you see a plastic part underneath between the hinges that looks like a 2/3 of a circle that is the part that pushes the switch.
You should open the printers gut and place the loose part back in place. Be ware that flat cables' contact ends could easily brake! use precaution!
(if you shake your printer you may hear the sound of the lose part).
Happy solving problems!
Bruce
on Feb 01, 2010 | Lexmark MFP-X3470 All-In-One InkJet...
Tip
Hi
Bruce
on Feb 01, 2010 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Open cover problem
You have go to service, becouse the switch for cover is brouken, and they need put them ih close mode. In same primter model switch is in diferent placeses
Sep 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
How can I scan without problems on a lexmark x3470 all in one
Hi..
To scan a document using the Lexmark Imaging Studio on ur Lexmark X3470, follow the steps given below:
1. Go to "Start," "All Programs," Lexmark X3400 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
To make a standalone copy:
1. Load the paper.
2. Select the "Copy quality" you want.
3. Open the top cover of the All-In-One.
4. Place the item you want to copy face down on the scanner glass. Make sure the upper left corner of the front of the item aligns with the arrow on the right of the All-In-One.
5. Close the top cover.
6. Change copy settings as needed.
Press "Black Copy" or "Color Copy."
hope this was helpful...
Apr 24, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
your printer needs to be opened and checked. plz ask some professional on your area to help you
Jan 13, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 has cover open in display will not do anything now
you need to open cover and undo and remove the grey cover inside the printer as there is a switch at back of machine which has *** off
Sep 29, 2008 | Lexmark MFP-X3470 All-In-One InkJet...
COVER OPEN
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
235 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
