Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox soda dispensor does not get cold
I took off the back and looked at it. the little black box clicks evry once in a while. on the circuit board D10 and D11 lights were solid red where it says out. i dont know if they are supposed to be on. i also looked at the pipes and did not see any oil or wet spot that would show i am leaking freon. the pipes were warm though. i dont know if there supposed to be or not.
  • 410 Answers
Sounds like the comp relay is bad or the compressor itself is bad the relay is inexpensive and easy to replace. the compressor on the other hand is not available to be replaced for this unit as well as cost prohibitive.
Posted on Jan 22, 2009
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my sky box works but when I push for a soda all
There is a little sensor board in the door where the flapper door is,you can access it when the door is open.That is what tells the main control that the can has fallen down through the door and the door has closed.
Aug 27, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Keeps freezing soda cans
well te best way to fix this is to lower the thing
May 29, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox does not get cold
Reed.. I had the same problem.. a maytag repair guy could not fix it .. Thanks to someone in FIXYA I got the part I needed ($23.00) Whirlpool 4387835 relay. I called the repairman and he would not returned the call.. So I opened up the box myself and carefully looked at the parts , replace the wires one at a time (it was easy) now I have cold beer just in time for baseball season pool side....lol Good luck!
Louie
Feb 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox stays at 50 degrees all the time
The SkyBox was built for Maytag by a company in China. Production stoppedabout 2 1/2 years ago, and Maytag purchased ALL available service parts available at that time. As inventories are depleted, there will be no more parts available.
An issue with the SkyBox involved a build up of frost and ice on the evaporator plate built into the wall behind the dispensor assembly. This build up insulated the product from the evaporator coil. It also caused the circulation fan to stop running. Unplug the unit and leave the door open for 24 hours. Plug it back in, set the thermostat indicator at the 11:00 position and close the door. See if this brings the temps back down to the 36 to 42 degree range, I hope this helps.
Jan 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox will not get cold.compresser comes on and goes right back off
IM HAVING A PROBLEM WITH MY SKYBOX MODEL#MBV1976AAB, I HAVE HAD THIS UNIT FOR ABOUT 3.5 - 4 YEARS AND NEVER HAVE I HAD A PROBLEM I LOVE IT. LASTNIGHT I FILLED UP THE MACHINE WITH ALL OF OUR FAVORITE BEVERAGES I WOKE THIS MORNING TO FIND THAT IT ISN'T GETTING COLD IN FACT YOUCAN HEAR THE UNIT ON BUT NOTHING IS GETTING COLD. PLEASE TELL ME WHAT CAN I DO I HAVE SPENT A LOT OF MONEY FOR THIS PURCHASE NOT TO HAVE IT DIE ON ME IN SUCH A SHORT WHILE.PLEASE E-MAIL ME AT: ALYSIA.FITZ@YAHOO.COM
Jun 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
I just replaced my in-pieces starter relay and thermal swich with a Whirlpool 4387535 kit. My Skybox has been working fine ever since.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
Mar 13, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Sky Box Won't dispence
Since it's only one dispensor unit you should be able to eliminate "common" items and find out what controls just that one dispensor. The faint click may be from a bad relay (relay coil works but doesn't pass voltage on contacts). You will likely have to take the thing apart to check the control board. Here's a diagram of the unit so you can see where everything is at. I'd suspect the control board relay that controls that particular dispensor is bad or a loose wire, etc. http://www.partselect.com/Schematics/Maytag/VM10-1.gif
Jan 14, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
210 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
