Question about Toshiba Office Equipment & Supplies
Toshiba e732 screen stripe - Toshiba Office Equipment & Supplies
I have a copier toshiba e-studio 280 the problem is when i switch on the machine the screen of the monitor was blink and blink its not work to start properly (stripe screen) what the problem on this?
Posted on Feb 11, 2013
Error E 732 0001
E732-0001 Error Code: Reader Controller PCB is faulty
[ Case in the field ]
Description
E732-0001 can be displayed when a communication error occurs.
Cause
In the field, this symptom occurred because the Reader Controller PCB was faulty.
Field Remedy
1. Make sure that the connector between the host machine and the reader unit is securely fitted.
2. Make sure that the connectors on the Reader Controller PCB are securely fitted or there is no pinched cables.
3. Remove and insert the Main Controller PCB (Sub) from the Main Controller PCB (Main). If the symptom still recurs, go to the Step 4.
4. Replace the Reader Controller PCB with a new one.
E732-0001 Error Code: locks up during copying
E732-0001 can be displayed when a reader communication error occurs.
Cause
As a result of inspection, it was found that this symptom occurred because of poor soldering of J1302-34pin on the Main Controller PCB (Sub).
Field Remedy
1. Make sure that the connectors are securely fitted between J1302 on the Main Controller PCB (Sub) and J502 on the Reader Controller PCB and that
there is no pinched cable.
2. If no problem is found, replace the Main Controller PCB (Sub) with a new one.
E732-0001 Error Code: Because of poor contact of SDRAM
Description
E732-0001 indicates that a reader communication error has occurred.
Field Remedy
As a result of inspection, it was found that this symptom occurred because the SDRAM was not securely fitted on the Main Controller PCB. So, remove
and insert the SDRAM once again.
Sep 26, 2013 | Canon imageRUNNER C3200 Copier
I have canon c2620n and when i turn it on give E 732-0001 i need help pleas
Description
Cause
Field Remedy
Cause
Field Remedy
Description
Field Remedy
Jan 31, 2011 | Canon imageRUNNER C3200 Copier
Where can I get drivers for my laptop e-machine e732?
Go to the e-machine website and search for your model, in this case the e732.
Jan 02, 2011 | Acer Computers & Internet
I have a Toshiba A200 and the screen is completely
Sounds like the screen is faulty I would check the screen connection to make sure its not lose but I would say the screen is almost gone.
You may need to replace it.
Feb 25, 2010 | Toshiba Satellite A200-19501F Notebook
Ir 6000 E225 and E732 not go off
e225 - chk ccd unit connector image board
e732 chk scan readder controller,connector
Feb 09, 2010 | Canon imageRUNNER 5000 Copier
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to ''turn switch off and on''. What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
2. Turn ON the main power switch.
3. Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
- Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
- Color Image Reader-E1: Platen cover model
- Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
- Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
4. Turn OFF the main power switch, and connect the DDI cable.
5. Turn the main power switch ON.
Note: How to turn OFF the main power switch.
When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
1. Hold down the control panel switch for 3 sec or more.
2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Nov 17, 2009 | Canon Office Equipment & Supplies
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to "turn switch off and on". What could be wrong?
Nov 17, 2009 | Canon ImageRunner 2220N Copier
Partial blackout on Screen
I have the same laptop, and though I havent had a black out problem i do have screen burn or a discoloration in the lower corners of my screen. I was told that It was due to this model's overheating issue and that I would have to replace the screen.
Apr 20, 2008 | Toshiba Satellite M45-S331 Notebook
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
