Question about Aerolatte Coffee Makers & Espresso Machines
How to repair aerolatte 6 months old
Wand fell out of socket
How do i fix a tricicty bendix dryer
You need to call a technician. If this unit is only 6 months old, it must be under some type of warranty.
May 04, 2015 | Tricity Bendix Washing Machines
How do I replace batteries on aerolatte pro
Check that the end cover is on properly and that the contact in the lid is intact (positive terminal).
Oct 31, 2014 | Aerolatte Milk frother with Stainless...
Repair extension on miele vacuum?
My Hoover had the same problem. I disassembled the plug and socket and cleaned all contacts with alcohol, gently compressed the prongs in the female socket with a pair of pliers so they would grip the male pins more tightly, and reassembled everything. If your wand's socket won't come apart, use Q-tips to clean the contacts and a pair of small screwdrivers to squeeze the prongs together. Also, my wand had a some play in it which caused the contacts to loosen up in the first place, so I used adhesive-backed felt strips to keep it from wiggling. So far so good -- I'm at 18 months and counting!
Oct 31, 2014 | Vacuums
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Dec 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I fell into water with my Canon 400D.. it doesn't work. can i fix it??....i am really sad ..that i can't use this.. it's only 6 months old..:'(
Too bad but the water will have ruined the circuit board
Nothing anyone can do about this sort of mishap
Aug 12, 2008 | Cameras
Battery will not charge
Through this in to gabbage
May 28, 2008 | Pantech Duo Smartphone
Coffee Makers & Espresso Machines Logo
485 people viewed this question
Top Aerolatte Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Aerolatte Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
