Question about LG DBRH197H DVD Player/HDD Recorder
LG DBRH197 I am also having troubles using the timer recording. The unit allows me to set up a recording session. Everything appears fine on the " Timer Record List" e.g the check says that Rec.Ok. When it comes time to record the check changes to "Duplicate Date". There is only one session set up and the date is fine. I cannot work it out.Could some please help me out. Thx
  • Anonymous Mar 18, 2014
    I set the timer to record but most of the time it keeps recording past the time and I don't know how to stop it. Also sometimes I set the timer record and it doesn't even start
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Posted on Aug 02, 2007
We have an old LG HDD DVD recorder. We are currently recording all our videos onto the hard drive and transfering them onto disc, but apparently there's some sort of code that won't allow any disc...
U can't get rid of their patended codes sorry,but u can bypass their patended codes by recoppying it all over again with a computer with a movies coppying software by buy an install software on your computer for recoppying it all over again,than u can play into any DVD player u want.
Jun 12, 2011 | LG DR787T DVD Recorder
LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Jan 17, 2009 | LG Corbel A- Accessory Range Hood
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LG DR275 timer recording problem
I found the answer to the problem eventually,it was because when setting up the recorder I had set the clock to 2007 instead of 2008 everything now working OK
Mar 07, 2008 | Televison & Video
Recording DVD's on Samsung DVD-VR320 Recorder
See if a shop will clean the optical assembly for you at a reasonable cost. Also, if you have the "finalization" feature turned off, this will cause a disc to show that message...accordianman
Feb 25, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
DBRH197
It only has a standard definition stb in it, the unit doesnt support high def. sorry, ****-face
Jan 11, 2008 | LG DBRH197H DVD Player/HDD Recorder
LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Aug 13, 2007 | LG RH177 DVD Recorder/HDD Recorder
LG DBRH197H DVD Player/HDD Recorder Logo
512 people viewed this question
Steve Allison
Steve Allison
