Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
My TV turns off by itself. How do I correct this? my tv turns of after 10-20 minutes and blinks 3 times red after being off. How can I fix this.
  • 59 Answers
This is somtimes do to an old lamp causing the tv to over heat and shut down. wich would also explane the error code (blinkinglights after shut down)
Posted on Jan 22, 2009
I have a Sony Bravia LCD TV Model: #KDL-46W5100 SN:8020524. When I turn on the TV all it has a great picture & sound. After apx. one minute it will lose the sound and then it will turn itself off. Then...
G'day Lee, sounds like you may have a 'dry joint' meaning the solder has come adrift, to open the back up will need special tools to fix it. Hope you can get it fixed. Cheers Greg.
Mar 04, 2015 | Sony BRAVIA KDL-46W5100 46" 1080p LCD TV -...
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Flashing red light on front of Sony Wega flat screen tv
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 16, 2009 | Sony KDL-46VE5 LCD TV
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Sony - Projector TV won't turn
Sony TV;s will give a service code, count the blinks, eg; 2-6, light will blink X amount of times, hesitate & blink again so many times. Count and report back but, I would recomend to unplug the TV's power cord, to reset the TV's system. Unplug for at least 3 minutes. I hope this was helpful.
Jun 11, 2008 | Televison & Video
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
