VANGUARD 6E739 PILOT GENERATOR PARTS - Heating & Cooling
Why does my Vanguard 8000 generator pop the 40 amp breaker on the generator when I plug in the 30 amp cord into the generator .
There's either a short in the cord somewhere, or the breaker on the generator is faulty and needs replacing.
Feb 24, 2015 | Voltmaster Generator 8000 Watt 16 HP...
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Jan 31, 2011 | Vanguard Heating & Cooling
When the heater has the pilot lit we can not turn the thermostat to light the elements.
Try pushing the control knob down sightly and turning it counter clockwise to ON position. If it won't turn, this usually indicates that the control valve has locked up. Turn the pilot off and wait 5 minutes, Relight the pilot and try turning it again, as described above. If it still doesn't turn easily, the Control Valve will have to be replaced. It's not an inexpensive part, as it's the heart and brains of the heater.
Also, DESA International the manufacturer of your Vanguard heater is no longer in business. However, some parts are still available. Do a Google search for Vanguard Vent-free Heater Parts and you may have some success in find it for your specific model number.
It's rare for a control valve to lock up or fail. It's usually caused by someone trying to force the control knob to turn with a pair of pliers and usually in the wrong direction. Which breaks the plastic gears inside the control valve. I'm not saying you did this, it's just what usually causes it.
Jan 26, 2011 | Vanguard Heating & Cooling
Vanguard wall heater pilot will light but when to turn on heat it goes out. Thermocoupler??
This is a very good possibility and depending upon the year they may call this part a flame generator. So ask for both when purchasing. Before you run out and purchase this take five minutes and try this, I use steel wool or light grit sand paper and clean up the bulb end of the thermocouple then place it top center of the flame as this is the hottest area of the flame, now with a small wrench check to see that it is tight in the gas valve. Now try lighting the pilot and then the furnace. Some times a simple cleaning and tightening can cure this problem. If not now you can go and purchase a new one.
Dec 27, 2010 | Vanguard International Infra Red - Medium...
I purchased a used Vanguard vent free radiant heater but did not recieve an owners manual. How do I adjust the pilot and burners? Is it possible to get an owners Manual for model VP10TA. Louise ...
Vanguard which is not made anymore is part of the Desa Tech family.. You will find all the manuals for the Deas Tech family at:
http://www.desatech.com/
and mom next time call and ask.
Little Arch
Dec 10, 2010 | Vanguard International Infra Red - Medium...
Pilot wouldnt stay lit. replaced the thermocouple and now pilot wont light at all.
Hello Make sure the gas is on and be paitent you have to purge the air out of the pipes/tube to light pilot.
Sep 19, 2010 | Vanguard International Vanguard BY Rheem...
Have a model up26t serial#010782007,lights and burns good for 10 minutes or so. Then you here a click up in the control area and it shuts flame and pilot light off. If you wait a little while you will hear...
The manufacturer has a website (www.desatech.com ), they list part distributors on that site this should help you in your search. It should like you need to replace the thermocouple or the ODS pilot assembly... this is the most common problem with these units. I think your model must be a VP26T if is a Vanguard unit?
Jan 27, 2010 | Vanguard International VN30TB Infra-Red...
The flame in weak and it heater will not light
You need to replace the ODS pilot assembly.A low pilot flame will not allow sufficient heat to generate proper voltage to hold valve
Nov 13, 2009 | Vanguard International Infra Red - Large...
Pilot on logs won't stay lit
Hold pilot button longer. if this doesn't work your Thermopile has gone bad and will not generate enough Millivolts to keep gas valve pilot open. A new thermopile will generate 750 millivolts. It cost less than $20 dollars but is difficult to replace. You should call a certified technician. They will charge you about $100.00
Oct 19, 2009 | Desa International Wall/Window Air...
Governor problem on 9 hp vanguard engine
Go online to Generac and they have parts list and owners manuals online. They will ship you parts.
Jun 25, 2009 | Generac 5724 GP Series GP3250 Portable Gas...
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
