Question about Andis Experience Professional SMX MVP 2 Speed Clipper w/ 2 Detachable UltraEdge Blades 000 & 1
Replacing andis MVP cord - Andis Experience Professional SMX MVP 2 Speed Clipper w/ 2 Detachable UltraEdge Blades 000 & 1
Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
My Pro Finish 714 cord was accidentally cut. Is it worth replacing the cord? Where do you get a new cord and can I replace it myself?
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
Mar 04, 2011 | Black & Decker ProFinish X750 Iron
No power from cord. I want to replace the cord.
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Nov 04, 2010 | Euro-Pro Shark GI490 Iron
Hi Our Breville IR80 iron needs its mains cord
If you google 'Security Bit Set' you should be able to find a set of screwdriver bits that will contain one to open the iron. (I think the forked bit in question is called a 'spanner' bit.)
I've just ordered a set from Amazon.co.uk which you can find by searching for 'Screwdriver Bits Torx / PZ / PH / Flat Hex Spline Extra long Security 50pc AT822' at their website.
Nov 01, 2010 | Rival IR800 / IR810 Iron
The cord needs replacing
replace the cord
Mar 30, 2010 | Irons
I have a DX 6700 that does not come on when plugged into the outlet.
Hi.
Either the wiring to AC power line is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
If the power cord is fused (like for example in UK), check also the fuse in the power cord, try replacing it.
Regards.
Jan 17, 2010 | Rowenta DX6700 Iron
I've a ghd hair straighner and only heats up sometimes, what could be the problem? thanks
The power cord may be bad. When it does work, if the plug end or the wire at the straightener end gets hot, the cord needs replacing.
Sep 16, 2009 | Irons
Andis Experience Professional SMX MVP 2 Speed Clipper w/ 2 Detachable UltraEdge Blades 000 & 1 Logo
20 people viewed this question
Top Andis Irons Experts
Are you an Andis Iron Expert? Answer questions, earn points and help others
