Question about HP Pavilion dv6000t Notebook
No audio device installed - multi-layered issues
Hp dv6000 notebook
vista OS
__________________________________________________________
Many layers to this:
1. problem originally appeared after I uninstalled some programs from the start menu
2. spent almost 2 hrs online with HP - who could not solve it and said to reformat hard drive and start over -- NOT!
3. tried ALL the solutions I found on the forums - no go
4. found fixya -- cleverer 2 said I had trojan and/or virus - per instructions I downloaded spybot and ad aware - did 2 clean ups and indeed did have trojans .. problem not fixed, however
5. tried to install new hardware - conextant audio device - crashed computer 3X (this is the correct audio device, I believe)
6. flash also quit working - fixya said to download as administrator - did and it works
7. CLUE: after first download of flash - audio device appeared, but did not work --
8. CLUE #2 - each time I restart I have to re-install flash
9. Problem is NOT just driver - when you try to install is says "no media device"
Is this a registry problem? Should I download a registry clean up program? I have downloaded 2 free ones and done clean up - seemed to make things worse, actually ...
Could the actual hardware (sound card, whatever) be damaged?
If so, what is the fix?
There are TONS of people on the forums, all computer types, with this same problem -- most of them also have vista os in the equation ...
Looking for a happy solution. And so far, you guys and your network are THE most knowledgeable....
Seriously hope you can help .. I'll tell the world about you ..
Actually I already put you in my last newsletter ... (but it's not the world, yet)
  • mindsetforpe Jan 25, 2009
    system restore back a month - does not work
  • mindsetforpe Jan 27, 2009
    problem: audio device not installed message
    hp pavillion dv6000 - vista os
    solutions I have tried so far that did not work:
    1. system restore (3X - to a month before the problem)
    2. spybot & adaware - did work - did have trojans, but problem still remains
    3. install new hardware - conextant audio - crashes system and gives message about bios error
    4. install driver - doesn't work - can't find media device
    5. registry cleaner - no change
    problem started when i uninstalled a bunch of stuff from start menu - system restore put it all back, but sound still won't work
    media device has shown up 2X during all this, but there was still no sound ...
    now the red x appears on the icon ...
    hp support could not fix and said to wipe out hard drive and start over .. do not want to do that ...
  • 565 Answers
You have windows system files missing. Short of transfering your inportant files to a flash drive or two, and re-installing a fresh copy of vista, try this:
This solution is for XP, but vista is similar.
Insert your vista installation disk into your drive and re-boot. From the "install windows" box, select "repair your computer." From the "system recovery options" box, select "command prompt."
Once at the command prompt (blinking >) cursor, type the following, where Dis your cd/dvd drive letter. The "C" drive is usually where the operating system is installed.
1...at the command prompt C:\Documents and Settings\{your user name}>[blinking cursor "_"]
type this:
copy d:\i386 c:\i386
It will take a few minutes to load. After it finishes copying, type "exit" to end your session.
Then reboot your computer and that should do it.
Are there any further questions regarding this matter? If not, enjow :-)
Posted on Jan 27, 2009
  • Bob
    Bob Jan 27, 2009
    You can also run System File Checker. start>run>type in "cmd">then type in the following at the command prompt: sfc/scannow
    The computer may ask you to insert your installation cd into your cd/dvd drive.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, there were several versions of this laptop. Verify that the sound device is indeed a Conexant. There are other versions of the same model that uses Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03).
Good luck and Thank you for using FixYa.
    Sniper:
  • 92 Answers
Hello and welcome to FixYa,
Here is a link for the
Conexant Audio Driver version 4.8 for windows Vista,
Driver Download
  • Michael Cunningham
    Michael Cunningham Jan 27, 2009
    You can go to
    the drivers can be found at
    http://welcome.hp.com/country/us/en/supp...
    if you bought in the USA
    to find your exact product name look on the bottom of the laptop
    close to where the windows "key" sticker is and you should see a
    sticker that HP put there.
    should say:
    product: hp pavilion dv2000
    s/n: ###########
    p/n: ###########
    service tag dv2120us
    From there you can download all the drivers for you machine
    Brigadier General:
  • 5,158 Answers
Have you done any disassembly to that laptop lately .... like removing the cmos battery etc. ?
Robert
    Sergeant:
  • 320 Answers
Remove all the audio devices which you have installed earlear and install a fresh. for latest audio driver, click on the below link and select your model and select the operating system...
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=hp+dv6000+notebook+&submit.x=7&submit.y=4
or First try with Windows xp and later try it in Vista..
Thank you......
    President:
  • 2,559 Answers
First off the problem is,you are trying to use a driver for xp,the driver for vista is at the bottom of this page.
Click start,control panel,On the left hand panel,select (classic view) Double click on system, On the left panel,select (device manager) The the + beside Sound,video,and game controllers,select the audio device,Right click and select un install.
Once un install is complete,Go to the top and click the icon for scan for hardware changes,once new hardware is found,close the open windows and click here and run the Vista driver.If the link doesn't work,just copy and paste this into your internet search bar.
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36079.exe
Posted on Jan 22, 2009
    Sergeant:
  • 221 Answers
As you will have to install it again the latest drivers .just download it from net the latest software.it can also be the problem of any files get missing for this reinstall the windows again after formatting the operating system.
  • HP Master
  • 6,487 Answers
It seems you already tried running a lot of security software on this computer and still have the same problem, but if I'm correct you haven't run a system restore yet on the time and date that everything was working fine on that computer, so if you haven't tried that yet better do a system restore first and hopefully that will fix the problem...
  • HP Master
  • 685 Answers
Ok have you tried to reinstall windows from scratch also if you know the name of the audio card let me know
    Sergeant:
  • 378 Answers
Just do a system restore to your pc/laptop follow this instructions click start on the task bar--->then click all programs---->then click asseccories----->then click system tools------>then click system restore option-----> click next in the system restore option  there you select the date that is in bold and select that date at when your pc was actually functioning properly it will work properly. thanks.
Dv6707us no audio output device is installed
WOW no OS stated, w2000,xp,vista,w7,w8 or w10 wow. to the max.
no? toss coin W7 sp3, all updates good.
i bet BIOS is fine, after all it worked before, SURE DID!
so what is it,
well my guesses,,
1: system is virus infected, do a full HP media reinstall. end. issues.
2: if device manager is missing? all your key hardware!!!
that means windows lacks the base line drivers for you your LT.
tell me someone installed non HP,com OS from say MS direct.
there are only 2 sources of OS
HP
and
MS.
ok went to Hp.com for you
shows its VISTA, this is some old LT. circa 2007
(10 years old) but has very very old buggy vista.
so if not vista, loaded from HP
then its the wrong OS, installed. (is it wrong?)
next time say what OS is there, so helpers can even begin to help.
now how to load fresh Vista on this box LT.
there are 2 ways, (there is a 3rd I will not cover)
1: put in the HP recovery CD and load it. bingo fixed.
2: install windows vista someway, (missing all your unique chip drivers. then
on the below web site you would install all drives manually
taking about a days labor.
they must be installed in the correct order and correct version
and precedence.
on newer LT , HP as a softpaq, loader, that loads them all in the correct order and all that. but on this old laptop , no SOFTPAQ
autoloader is offered, best i can tell.
on mine 2
only this works on your LT.
http://support.hp.com/us-en/drivers/selfservice/HP-Pavilion-dv6700-Entertainment-Notebook-PC-series/3632100/model/3648473
Mar 11, 2017 | HP Pavilion dv6707us 15.4" Widescreen...
I downgraded my presario v3000 from vista to XP..it was succesful but i lost my audio...i can only hear sound when i use my blue tooth
For that you need to install sound driver.
Click here
Click on above link and select your os and model then download audio driver and install then it will work fine.
Let me know if you need further assistance.
Thanks for uisng FixYa.
Jun 14, 2010 | HP 417065-001 - HP Compaq Presario V3000...
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv6516tx internal dvd writer not writing to blank dvd
you can check the capability of your drive with nero so you know which disk u can write to.
Jun 30, 2009 | HP Pavilion dv6000z Notebook
I need high definition audio driver for HP pavilion DV6000 P/N KW103EA
xp drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=pt&cc=br&product=1842155&lang=pt
vista drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=pt&cc=br&product=1842155&lang=pt
audio driver is the first on each page.
if you have problems make sure you have the correct model. this is for hp dv6000 but you should check in the bottom of your laptop near the windows registration label
please rate this solution
Jan 26, 2009 | HP Pavilion dv6000z Notebook
Multi-layered problems... active x, audio device not installed
See if this will let you install flash player...in windows explorer opern the folder holding internet explorer...usually c:program filesinternet explorer...then right-click in iexplore.exe and select "Run as Administrator". You should be able to go to the Adobe website and install the flash player. If not, go try going here and just download it and install from your hard drive........
http://www.softpedia.com/progDownload/Macromedia-Flash-Player-Download-24146.html
Jan 19, 2009 | HP Pavilion dv6000z Notebook
I have an HP Pavilion DV6000. No problems for 3 years. I haven't made any changes recently to settings or otherwise but suddenly I my wireless will not recognize LAN and I have no audio whatsoever. I've...
What is the exact model. This system is under recall for amd but you have to be within a 2 year period from the time you purchaced the machine. You can contact hp and see if you qualify.
Please do not forget to rate me :)
Dec 02, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv6000t Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
