Question about Belkin (F5D5231-4) Router
Can not access my belkin f5d72230-4
Was trying to set up my belkin and changed use as access point. Now when I try to log in it wants a pass word, admin won't work. Reset the router tried the default gateway address no luck ???
Thanks Thom
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Type this in http://192.168.2.1/ and press enter.If you have reset the router there is no password just press enter and you should be able to access your router. If this does not work reset the router again. Unplug your router and cable modem. Plug your cable modem back in first and then the router about 3-5 minutes later. Then type in the http://192.168.2.1 and press enter. Please rate answer. Thanks.
Posted on Feb 17, 2009
How to secure my pass word
Take a look on these point for password security :
Change your Default Password , Set up a security key for your wireless router, Try to priorities WPA than WEP for more protection, Disable your remote administration setting and Enable your router Firewall and MAC Filter. Try Security set-up http://www.ehow.com/how_4829036_secure-belkin-wireless-router.html and Router Support for more help.
May 29, 2014 | Belkin Basic Wireless Router
Not able to access internet through belkin F5D7230-4 router
1.the installation CD is important and can be obtain through the manufacturer. It has pertinent files that are necessary to communicate with the operating system and the hardware on the PC.
2.Call Belkin and get a replacement CD
Jul 03, 2010 | Belkin (F5D7230-4) Router (587009)
Change the IP address
There are a couple of things you could have done. Did you turn DHCP off? Are you just trying to use this as a WAP? The easiest thing to do is plug your computer into one of the ports on the Belkin, and nothing into the LAN port, do an IPCONFIG release and an IPCONFIG renew and let the computer get a new IP address. Then try logging into the gateway address displayed.
If you're doing a WAP, set an SSID, set the IP address to your 235 and gateway to 1, turn off DHCP, or let it pass through, because you're going to let the Linksys give out all IP's, then plug the linking cable into network, NOT USING THE WAN port. From the network, you should be able to ping 192.168.1.235 if you can, point your browser to that address and see if you can now log into the Belkin.
If you run into trouble, comment back and I might actually download the manual :-)
Carl
Nov 07, 2009 | Belkin F5D7234-4 Router
Trying to set up a vpn server on windows XP using
Did you already forward port 1723? I guess you have done that. To isolate it, try to bypass the router and setup or establish the VPN session there. If it doesn't work, maybe your ISP doesn't allow port 1723 or it's just the modem.
Oct 22, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Can not save IP
no way.
The only way I found is to change my own IP/mask to match Belkin's one, then use the web management to change the ip and mask for belkin. Then back to the previous ip/mask for my pc.
Aug 30, 2009 | Belkin (F5D7132) 802.11b/g Wireless Access...
Can't change back from access pont
You must press and hold the reset button for about 20 secs. Otherwise you are only rebooting.
Jul 07, 2009 | Belkin Computers & Internet
Configuration of Belkin Wireless Router F5D6231
Whoops, found it. http://cache-www.belkin.com/support/dl/f5d6231-4_manual.pdf
If I were setting this up for myself or a customer, I'd keep the Airtel IP's and let it be the DHCP server. To do this, you pick a fixed IP address for the Belkin, something like 192.168.1.251. Log into the Belkin and change the LAN IP address to that and turn off DHCP. Those instructions start on pdf page 34.
Now, plug one of the 4 ports into the Airtel, and from a computer connected to the network type in 192.168.1.251 in Internet Explorer. It should get you to the Belkin where you finish setting it up for wireless security and password from page 38.
You won't use the WAN port.
Carl
May 31, 2009 | Belkin Wireless Cable/DSL Gateway Router
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Belkin F5D8233-4 router & I pod touch wifi
What I would try is while the wifi is unsecure go on the computer and open up the browser you are using, on your router the default ip address is 192.168.2.1moz-screenshot.jpg
type the router default ip address in the browser where you would normally type a web address www.google.com
Logging into the Router
You will see the Router’s home page in your browser window. The home page is visible to any user who wants to see it. To make any changes to the Router’s settings, you have to log in. Clicking the
“Login” button or clicking on any one of the links on the home page will take you to the login screen. The Router ships with no password entered. In the login screen, leave the password blank and click the
“Submit” button to log in.
Configuring the Wireless Network Settings
The “Wireless” tab lets you make changes to the wireless network settings. From this tab you can make changes to the wireless network name or Service Set Identifier (SSID), operating channel, encryption security settings, and configure the Router to be used as an access point.
Setting up an Allow Access List
1. Select the “Allow” radio button (1) to begin setting up a list of
computers allowed to connect to the wireless network.
2. Next, in the “MAC Address” field that is blank (3), type in the
MAC address of the wireless computer you want to be able to
access the wireless network, then click “<<Add” (4).
3. Continue to do this until all of the computers you want to add
have been entered.
4. Click “Apply Changes” (5) to finish.
this will allow only the wireless device you select to access your router.
Mar 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231-4) Router Logo
180 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
