Question about Studio RTA Producer Station Maple
Studio rta producer station parts - Studio RTA Producer Station Maple
Hi i allredy moved to new house 23/01/17 but rta took money out of my acount for my old house
take it up with RTA and make sure that all the information is updated
Feb 03, 2017 | Computers & Internet
I,m trying to find charger for a kraft tech 18v cordless drill. Can anyone help?
there are two components require to charge a kraft tech 18v battery.
A power pack (power suply) and a battery station. The power pack says 24v DC 400mA but produces 34v DC at no load. When the power pack is connected with the battery station a green led lights at the battery station and the battery station produces 32.4v at no load( i mean without put the battery on to battery station. I believe that if i put the battery at the battery station the voltage drops to 24v DC, which is the voltage that the power pack says. I'm sorry but i can not measure the voltage that produced from the battery station when the battery is on it because my battery is dead and has shorted elements.
I hope that was useful.
Greetings from Hellas (aka Greece)
May 31, 2012 | Drills
I have an RTA International Patio Heater, Model 385.001 with a clogged pilot light valve. I need a way to fix the problem or a new replacement part. I have a commercial gas heating repair company working...
Gas Valves are not meant to be repaired only replaced. So I would have them replace the part and have them warranty there work. If the heater is very old and the replacement part is going to be half the cost of a new one You might want to put that Money on a new one and get a New manufactures warranty in the deal. Just another point of view....... Hope this helps
Feb 07, 2011 | Rta International Patio Heater
Can't receive or send fax
~ Configure Fax Settings ~ Check Communication under Fax Settings
drd: all ecm: off v.34: off dial tone detection: on RTA: RTA of the fax must be higher than the RTA of answering machine ~ Check the physical connection of the fax ~ line port must be connected to a phone jack ~ if you're using DSL (Internet), Use DSL Filter
Jul 06, 2010 | Lexmark Office Equipment & Supplies
Setting up rta on a driverack pa, system willnot
As far as I know, you just turn the dial so that you can hear the pink noise at what you expect to the the normal listening level, hit "next page" then the system starts "listening" and adjusting automatically. If you set the RTA to high resolution it can take a while. At this point you shouldn't be trying to hit next page. Just wait for a while. Maybe 5 to 10 minutes if you're on high resolution, depending on your room and setup. Let it go through and EQ. After a while you'll get a black progress bar at the bottom of the screen, sort of like a file download progress meter. Let it finish. If it's taking too long check the manual for how to change the auto eq to low or mid resolution.
I hope this helps. From your post I can't tell exactly what's going on. Reply with more info if you like and I'll try to help again.
Dec 06, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
My Nikon Coolpix 7900 digital camera produce .MOV 640x480 dv films. They can´t be used in Sony Vegas Movie Studio 8d.I can play them in Quick Time and VLC player. What to do?
Hello there amarylis_la_.
Here's your GEEK-steer ...
== INTERPRETATION ==
What I'm hearing is:
  • It's not well enough that you are able to view the output of your Nikon (or at least not with Quick Time and VLC player only), but you wish to edit it as well?
  • Your Sony Vegas Movie Studio 8d cannot open/import your Nikon's produced files?
  • Your Nikon produced output files are extension .MOV?
== ANALYSIS ==
If all the above is accurate, then I'm a bit perplexed. Here's why:
  • Per the publisher's own webpage, version 9 accommodates import of "AVI, MPEG-1, MPEG-2, MOV, WMV".
  • Mmmm, so then maybe Sony Vegas Movie Studio only added .MOV format import capability sometime after your version 8d?
  • However, although I couldn't easily find a specific import spec list for version 8d, this publisher description states version 8d can "edit video in nearly any format". Given the fact that version 9 does accept .MOV, and .MOV certainly being common standard enough to reasonable be expected to apply as "nearly ANY format", it seems strange that you're unable to open/import it.
== QUESTIONS ==
  1. Are you receiving an error message of any kind upon attempting to import/open the file?
  2. Is .MOV listed in "Sony Vegas Movie Studio"'s open/import "Files of type:" drop-down list?
  3. When analyzed with G-Spot, what video codec info (upper right) is reported on your Nikon output files?
== CONCLUSION ==
  • If indeed your Sony Vegas Movie Studio cannot import your Nikon produced video, AND you require being able to edit it, your only option is to get another video editor/converter that will.
  • If you post back describing what your specific objectives are (set-top DVD Player/portable-device playback, clean-up editing, more comprehensive creative editing, etc.), I'd be happy to recommend capable freeware/trialware software choices that will "FixYa" up (pardon the pun).
Thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed – Craig
Sep 27, 2009 | Sony Vegas Movie Studio Platinum 8
Bad thermocouple in RTA International Pation Heater
try national energy they do spare s never worked on one fitted one , thermocouples are nornaly just two nuts sorry cant help much more
Jan 22, 2009 | Rta International Patio Heater
RTA International Patio Heater Won't Burn Properly
I would check the burner is not blocked and check the injector as well.
May 06, 2017 | Rta International Patio Heater With Table
Create access mdb file by vfp code
Try this
#define dbLogical 1
#define dbNumber 2
#define dbInteger 3
#define dbLongInteger 4
#define dbCurrency 5
#define dbSingle 6
#define dbDouble 7
#define dbDateTime 8
#define dbBinary 9
#define dbText 10
#define dbOLEObject 11
#define dbMemo 12
#define dbReplication 15
#define dbDecimal 16
if file("C:\accesstest.mdb")
delete file c:\accesstest.mdb
endif
public oAccess
oAccess = createobject("Access.application")
oAccess.visible= .t.
newMDB = oAccess.NewCurrentDatabase("C:\accesstest")
newtable = oAccess.CurrentDb.CreateTableDef('testtable')
with newtable
.fields.append(.CreateField("Field1", dbLogical))
.fields.append(.CreateField("Field2", dbNumber))
.fields.append(.CreateField("Field3", dbInteger))
endwith
oAccess.CurrentDb.TableDefs.append( newtable)
dbc2Convert = "\\tpdfiles\data\dfreeman\tip\data\rta\rta"
open database (dbc2convert)
dbgetprop(rta,"table",)
After it runs you will need to close the MDB and reopen it.
Oct 15, 2008 | Microsoft Computers & Internet
Studio RTA Producer Station Maple Logo
60 people viewed this question
Top Studio RTA Office Equipment & Supplies Experts
k24674
Are you a Studio RTA Office Equipment and Supply Expert? Answer questions, earn points and help others
