Back to:
Tags:
GE 24GP653 24
Lightning Strike?
posted by katykate on Jul 03, 2007
Our GE Model# 24GP653 has no picture, just a thin white line quivering in the middle of the screen. I believe this was caused by a recent nearby lightning strike. It did not strike our house but out in the yard several yards away. I'd like to fix it myself if I can, I'm pretty savy with my computer is it much different inside my t.v.?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 03, 2007
Not Rated (0)
CompuGuy44
Rank:Wiz Wiz
Rating: 83%, 757 votes
Yes it is. The inside of a TV can seriously hurt you even it's unplugged. The circuits and electrolytics hold a high voltage charge. You can check the fuses,it will be right where the power cord goes into the tv. But I would get a pro to work on it. If lighting did cause this to your TV, you could look into your Home Owners Insurance to pay for the damages.
Trivia:
On 24 October 1991, one resident of Chicago Heights, IL was comfortably sleeping in bed when....KABOOM. Lightning struck, traveled through a cable television line into the house, struck the bed, which then caught fire. The person was treated for shock. Insurance paid the rest.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Lightning Strike?:
I don't want to Accept this solution
Solution #2
Not Rated (0)
dodgecharger
Rank:Wiz Wiz
Rating: 82%, 264 votes
Assuming this line is across the screen horizontally (side to side), this means the vertical deflection circuitry is dead. In late model sets, there is a Integrated circuit package which drives the vertical yoke coils. Possible defects: the I.C. itself, bad solder connections where it solders to the board, missing voltage source to this I.C. (often around +24 volts), or a bad electrolytic capacitor in the associated circuitry. This latter often results in a non-linear picture, or less than full deflection condition, rather than a thin line only.
It is possible lightning caused this problem, (I've seen some rather illogical damage from lightning ) perhaps it produced enough of a surge to pop the I.C. or a fusible resistor in that voltage source noted above.
Thank You!
Can you Help with these Standard Televisions problems?
GE 24GP653 24" TV
I have an electronics repair business and Sam's does not...
GE 24GP653 24" TV
image is bigger than tv screen ... can't see text around...
GE 24GP653 24" TV
Why can't I get a universal remote control to emulate the...
GE 24GP653 24" TV
how do i program a suddenlink remote to work with the tv
GE 24GP653 24" TV
How do I get into the Service menu on my GE 24gp653
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
