Question about Hotpoint Aquarius WF000 Front Load Washer
Drum won't turn
Hi, I have a hotpoint WF 440 washing machine... the drum seems to have stopped rotating, very hard to turn around with hand.... checked belt and that seems to be OK,, got some movement after that, done a small wash..thought all was OK but it failed to finish and all the lights were blinking...i disconnected the power...What could my problem be? thanks Pat.
  • stanthony198 Jan 22, 2009
    Thanks..Danromoarris, I had a feeling it was the bearings alright! do you think it would be cheaper to buy a new one against repairing machine in about 4-5 years old allways on the go! Thanks. Pat
  • 101 Answers
You probably have a big problem. I found this problem a lot with front loaders when I worked for Sears as a repairman. The sales people always tell you that you can wash like 15 pairs of jeans in these or 20 towels or what ever. That couldn't be further from the truth though. If your drum is not turning and it is hard to turn by hand most likely the bearings in the drum are shot from the loads that have been washed. If you turn it and it is hard or makes a grinding sound then the bearings are the problem and you will need a new bearing kit. When you open the back you can see that there is a 3 armed adapter that holds the drum in place. This is the bearing kit. If your loads have been heavy then the bearings will start working over time and start to wear out faster. A lot of people will say that they didn't think that they were doing that heavy of loads but you have to think of it this way. With a front load washer all the weight is weighing directly on the bearing and it is a lot when filled with water. What you may not think is a large and heavy load may be one. That is really the only thing that I can think that the problem is. I hope that it isn't because it is a pain to change out. If you have any other questions let me know. I love to help and that's what I am here for. Good luck.
Posted on Jan 22, 2009
  • Dan Harris
    Dan Harris Jan 22, 2009
    I would suggest pricing it out. It might be more beneficial for you to but a new machine just for the fact that it is a pain in the rear to fix that. When I did it working for Sears we would need two techs to do it and it would take a good 4 hours. Let me know if you have any more questions.
Hi, My washing machine drum appears to be loose. When the drum is turning slow it seems to go side to side as well as rotating. When the spin initially starts the drum seems to bang on the sides of the...
Sounds like worn drum bearing however check the top spring is not snapped.Remove lid you will see if spring is broken if not and suspect bearing its quite an expensive job,do you know Hotpint have a 5 year warranty on parts only call charge is around £105........Worthwhile considering as the parts would cost around this to buy excluding labour...Good luck
Jun 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
LG Washing Machine front loading, Model Fuzzy Logic 8.5KG,
If it has a belt remove this then turn drum by hand to see if noise is still present if it is then sounds like some thing caught in between drun inner and outer you may need engineer....Pull plug out 1st...
Mar 22, 2010 | Washing Machines
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Drum does not turn
The most common problem is with the belt drive.
Try this test. - Open the door, rotate drum by hand - is it free to rotate without any noise of driving the motor around? - If it is - order a new belt for it.
If you can hear the motor turning, try running the machine again. If movement is erratic - you need replacement motor brushes.
If you think the motor is dead, it may be - or there may be a fault on the control board. Both need testing to see. Usually one will need replacement.
Jan 05, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint Aquarius WF 430
Best way to check if the main drum bearings have gone is to;
  1. Remove back panel of washer
  2. Remove drive belt.
  3. Spin drum by hand from the inside of the drum, if it feels rough, or is noisy and rumbling, then the main bearings have gone.
If there is no apparent noise, then you will have to investigate further.
If I can help further, pleas let me know.
Plz rate my solution.
Oct 31, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WD420 1200 Spin
Hi I have an Indesit WE16 with some of those symptoms and cannot figure it out - so please don't rate this as useless yet! I am beginning to suspect a bad connection to the motor and I have noticed that the drum only turns anticlockwise in my case - if the program calls for clockwise rotation the machine just hums for a few seconds and then stops.
Does this apply to your machine?
Please add a comment and maybe together we can sort both of them out. D
Jul 22, 2008 | Hotpoint Aquarius WD63 Front Load...
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
114 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
