Question about Dell 3010cn Laser Printer
Printer was printing fine ran out of paper reload paper but it will not pick up the paper now a yellow light comes on and it says load MPF letter Plain 1 024-969
  • Dell Master
  • 5,568 Answers
I don't know this specific printer but have seen many printers mishandle the last sheet of paper causing a jam and leaving pieces behind when forcibly removed from the paper path.
You might try peering into the paper tray slot to see if there are any obstructions. Different printers use different methods of sensing 'paper out' and yours may use a mechanical flag that interrupts a photo sensor that really detects on the passage of the sheet and if this is impeded in some way, it may just think it's out of paper.
Posted on Jan 22, 2009
When I go to print I get message load mpf 024-969
This error typically means that the Size of paper defined in the print job being sent from the application does not match the size of the paper the printer has set for the MPF. (in this printer, MPF = Manual Feed)
For example: If you send a Letter size job to the printer from, lets say MS-Word, but the printer currently has Legal size paper assigned in the MPF, this error will result.
Change the Windows printer to default settings
Apr 03, 2014 | Dell 3010cn Laser Printer
MPF 024-969
Is the paper pushed all the way back into the MPF?
If yes, what type/size paper is your application sending?
If you try to print the internal Printer Settings report, does it print?
This error typically means that no paper is sensed in the MPF OR that the wrong type/size paper is in the tray. (MPF settings do not match job specs)
Oct 27, 2009 | Dell 3010cn Laser Printer
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
My Dell Color Laser Printer 5110 cn won't print. It keeps saying ''Load MPF Letter'' then ''Load MPF Plain'' then ''Load MPF 020-969
it's asking for paper in the manual Paper Feeder (MPF). Somewhere in your settings you have it printing to the MPF. Check the settings in the printer prefrences, the printer itself and the software you're using.
Cheers.
Sep 23, 2009 | Dell 5100cn Laser Printer
A dell 3010 which prints fine from webpages etc. but refuses to print from out look and says load plain mpf 024-969 when there is paper in the machine which it was previously happy to print on.... very...
Outlook's printer options are set to load paper from the Manual Paper Feed (mpf) instead of the regular paper tray.
In outlook, select file->print and look for the printer properties button on that dialog box.
Select the paper tray you want to use (or simply uncheck "MPF" or "Manual Paper Feed") and hit OK.
Jun 14, 2009 | Dell 3010cn Laser Printer
Dell 5100cn won't recognize mpf tray
Go to the printer web page by entering the IP address of the printer in an Internet Browser.
click Printer Settings menu entry
If the Substitute Tray value is not MPF Feed, click on the Printer Settings tab
Set the Substitute Tray value to MPF Feed
Click the button Apply New Settings, it will request the admin id & password for the printer.
In trying to resolve this issue, initially I set the Tray Settings to Panel Specified from Driver Specified at the printer's panel. Since the issue was resolved with this set, I just left it that way.
Nov 01, 2008 | Dell 5100cn Laser Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
3010 dell color laser
Ok,
I've went around and around with the same problem (bug) and finally found a solution. Here is the deal. You have to exactly match the settings for the MPF tray in the aplication softwares to the MPF tray settings set from front panel on the printer.
I found this problem when trying to print on gloss paper. The MPF tray had to be set for "Coated 1 Side 2" in both the application and on the front of the printer.
Lets say I'm printing a Word Document. Go to file, print, select the Dell printer, then select properties, select paper tray, set paper source to MPF, set MPF settings to ""Coated 1 Side 2". Click OK.
Now do the printer setup. From the front panel on the printer.
Press Menu, press the down button to Tray Settings
Press center button to select.
Display now asks for paper type. Press center button.
Displays MPF. Press center button.
Push down button until you see Coat1 Side2
Push center button to select.
Press Menu to exit.
I only print on gloss so I have to set the MPF tray to Coated 1 Side 2. I was told this slows the feed and that is needed for coated papers. Now you could probably use another setting as long you set both the MPF tray in both the application and the control panel to match exactly.
Aug 19, 2008 | Dell 3000cn Color Laser Printer
Dell 3000cn laser printer
This is usually related to the way the tray or trays are configured on the printer or the way the program from which your printing from is configured. If you are using ms office, as an example, if the instructions to the printer from the software (ms office) say to print this document to the Multi Purpose Feeder tray (MPF) using plain paper and there is no plain paper in the MPF, you will get this error. Conversersly, if the printer's MPF is configured to print only legal size paper, and the software you are using is sending a print job to the printer telling it to use letter in the MPF, you will get this error. Basically, the printer settings and the settings from the software must match in order for this error to not occur. The settings for the printer can be changed usinig the operators panel of the printer. Directions for this should be available in the users manual or from support.dell.com. The setings for the software shold be in the print properties/preferences of the software being used.
May 19, 2008 | Dell 3000cn Laser Printer
Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Jan 08, 2008 | Dell 3100cn Laser Printer
Dell 3010cn Laser Printer Logo
275 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
