Question about Canon PowerShot A530 Digital Camera
My power shot A60 has a white screen and wont take pitcures.
It flashes and clicks but it just takes black pitcures. I have reset factory settings and still the same thing white screen, I can see the menu but still cant see a pitcure, please help.
  • mellow5n2 Feb 15, 2009
    Camera approximately two and half years old. Batteries checked and lens is clean. Appears to take pictures but screen is black and only pictures that can be reviewed are ones taken before problem happened.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 24, 2009
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
I have a Toshiba G15 laptop that crashed during system recovey ghosting. Now it will do nothing but black screen and flashing hyphen. Any clues on how to get this up and running So I can do system...
Hello, go into your BIOS, make sure the hard drive is selected to boot from. Then, look for a setting for factory reset, make sure it is also enabled. Then shut the computer off for 2 minutes. Now hold the zero button down and press Start, windows should load and then you should see the factory restore/reset window warning you that all data will be lost. Click YES, select Recovery of Factory Default, then follow the prompts to get windows installed. Hope this helps.
Second solution:
Restart windows if the Factory reset does not work. Before you see the BIOS or windows logo, press several times on F8 till you see a black screen with a few lines of information. Click Last Known Good Config and then Enter.
Last Solution:
Restart Windows, press F8 several times before you see any writing or logos, once you see the black screen with a few white lines of information, press Repair my windows. If you get the windows could not fix this problem, select try another method, it should take you to another screen, select US, then user name, put in password if you have one, then select Restore.
Good luck
Mar 15, 2010 | Toshiba Qosmio G15 Notebook
Canon Power Shot SD 400 Digital Elph - image not on screen
On most canon elph cameras you can either go through the menu and reset back to factory default and this might solve the black or white screen. If that does not work you should be able to hold the menu button down for several seconds until a reset prompt pops up. You will then click on yes for reset and this should completely reset the camera and the screen should be back to normal.
Jun 10, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Fuji S5000 - screen is white or white and black in camera mode. Normal in picture viewing mode
Try resetting your camera.
Press Menu/OK -> SET-UP -> On page 3 there is a reset menu. Confirm selection. Camera will be set with all factory adjustments.
Nov 25, 2008 | Cameras
Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Kodak EasyShare DX7630 Digital Camera
HCT HDVR960S now only shows black and white panels on TV
sgtken,
I also purchased the same unit. Please let me know if you figure out how to get the unit back to factory settings. I checked over the unit and do not see a reset button. Thanks!
Bill
bjessip1@hotmail.com
Mar 30, 2008 | Samsung DVD-R155
Can only get black and white
1. Download and run a utility from Microsoft called AmCap. 2. Run it and select your webcam from the Devices menu. Verify the webcam output is visible. 3. Go the the Options menu and select Video Capture Filter. 4. Make sure that the Color Enable checkbox is checked, and the Saturation slider is in the middle. Or just click on Restore defaults. Hope that helps.
Jul 25, 2007 | Logitech QuickCam Pro 4000 Webcam
Stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Aug 04, 2006 | Cyberhome CH-DVD 300 DVD Player
Canon PowerShot A530 Digital Camera Logo
189 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
