Question about Whirlpool ED2SHAXM Side by Side Refrigerator
Plastic collar on door ice dispencer
The plastic collar on the door ice dispencer has come off. How do you put it back? What does it clip on to?
  • 410 Answers
As long as its not broken you will see 3 tabs on the back of the collar one looks like a downward hook and the other 2 are across form oneanother and look like clips. slide the hook end into the square hole on the dispenser lever then tilt the top 2 clips up toward the disp door. it is a very tight fit i usually can get it past the cover with a little force. if you think it may break you can remove the disp cover by prying the cover off at the 2 slots located on the bottom of the disp cover. good luck peyton
Posted on Jan 22, 2009
Light in freezer side will not work also will not dispence ice
if it is a fuse / the fuse is located inthe wire harness on the side of ice maker . it is in a clip and looks like black plastic . four wires oly the one in clis is fused. mm
Jul 16, 2010 | Kenmore Refrigerators
Whirpool side by side- opening for through door ice dispenser will not close all the way after dispencing ice. Causing condensation and loss of cool air. Any fix available?
Hi;there is a little plastic valve set up that return the ice flat. Fiddly joba and patients required so you don't brake anything else, that somethings sticks and won't allow flap to fully return. If that doesn't work, tape the flap up and open the freezer door and retrieve ice that way
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have my ice maker set to cubes, only dispenses crushed, and now "nothing"
remove the ice bin then hold it over the sink and lift the small arm located on the back of the dispenser if it opens and cubes fall out this is good.
the next thing to look at open the door and look at the auger motor case and you will see a small hole in the back with a square plastic actuator make sure this is down.then hold the door switch and have some one try and dispence ice the piece of square plastic should move up if it does not the it needs to be replaced.
if it moves up just make sure the metal arm on the back of the dispencer bin is properly inserted in the plastic actuator.
Jan 24, 2010 | Frigidaire GLRS264ZA Side by Side...
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
The ice dispencer accumulates ice and clogs the opening. also the dispenser only servers crushed ice even when the cube button is pushed
you have two problems. First the ice build up is because the dispensor door is not closing all the way and the air is causing condensation and freezing.
you will half to find out why the door is not closing. it could be a bad door or the solinoid could be bad.
The second problem is that the solinoid in the back of the freezer is not moving the ice bucket arm.
Common problem is that the solinoid is bad or the plastic arm on the solinoid is broken.
Jan 07, 2010 | Refrigerators
Door inside the ice dispencer sticks open. have to push it close
Sounds like the clear plastic door guide on the ice dispensor arm , is broken loose , holding the door , keeping it from closing . If this is the problem , it just snaps on . If a piece is broken from the guide , pt # 985866 is usually the part .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Removal of rear outter door handle
Ok
Remove plastic plug on the inside of door there is 10 mm hole use a hooked pick set pick put through the hole and pull the plastic cir clip towards the back of the door that will release the smaller part of the outer handle then the handle itself can be taken out.this is so simple but so deceiving the actual cir clip is hard to notice because of all the plastic **** on the inside backing plate the cir clip is just on the inside of hole look hard it is 2mm thick & 20mm high (black plastic) place point of pick in between backing plate & cir clip hook it and pull back the front door is based on the same principle but is a lot easier
Jun 10, 2009 | 2008 Audi Q7
A part fell out of the ice maker - makes 'soft' ice???
It goes on the bottom of the ice tray and snaps in that is the sencor that tells when the ice is frozen
Mar 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool ED2SHAXM Side by Side Refrigerator Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
