Question about AVC DA09025T12UP Server - Round Fan Server
AVC DA09025T12UP heat sink - AVC DA09025T12UP Server - Round Fan Server
  • etrc_new Dec 24, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? and what's the question ?
What is an avc system
Advanced Video Coding: a type of standard for the compression of digital video. AVC helps to set the standard syntax for video formats such as Blu-Ray, mobile TV and teleconferencing.
In terms of its origin, AVC was developed jointly by the International Telecommunications Union (ITU-T) and the Moving Picture Experts Group (MPEG), which is a project of the ISO/IEC and familiar to many users because of popular and accessible MPEG file formats, like .mpg.
Experts point out that AVC is a prominent alternative to an MP4 format. When comparing AVC to MP4, it's important to consider that AVC has a bigger compression ratio and longer encoding than MP4, and that more central processing power is needed. However, experts also point out that the storage efficiency of AVC is greater than those of some previous MPEG formats.
The actual methodology used to encode and decode video with AVC involves three distinct phases labeled "predict", "transform" and "encode." The mechanics of AVC break video down into a kind of machine language that can be easily stored and accessed by a range of technologies.
Mar 03, 2015 | Televison & Video
I have denon avc 2530, now it is showing :Protect: which is i cannot remove, may u help me. ilyasfarhan.dp@gmail.com
There's an overload. Generally caused by a short in the power amp stage. Check the device(s) on the big heat sink.
Feb 18, 2014 | Audio Players & Recorders
Clean heat sink
Yes you can, remove the cover off the desktop computer to get access to the fan and heat sink over the CPU.
Use a stiff brush to loosen the dust off the fan and heat sink and vacuum the dust off the fan and heat sink. You may need to use a can of compressed air to blow the dust off the fan and heat sink then vacuum the dust out.
Aug 24, 2012 | Gateway GT5220 PC Desktop
Hitachi 42hdx61 keeps turing off
Mine does the same thing, I took the three screws that hold the cover on the AVC out,removed the cover and put a fan on the boards that are behind the power light,that the cable to the tv connects to,and mine has not done it sense,not sure how long but the problem is that when under heat something in that area is failing.or this is a engineer problem not adequate amount of air flow on there AVC,s.Because of the amount of complaints for the same exact problem
Dec 31, 2011 | Hitachi 42 in. Plasma TV
Chipset heat sink not detected
The chip set heat sink is not properly installed on the system board.
Ensure that chip set heat sink is properly installed on the system board.
To locate the system-board chip set heat sink, see "System Board Components."
Feb 18, 2011 | Dell OptiPlex GX280 PC Desktop
I put a new power supply & heatsink with fan in my system & now I can't get it to power on. The heat sink was VERY hard to get on. I even put the old power supply back in & it won't power on....
If your CPU is sticked on the heat sink due to heat sink cement, could have damaged your CPU pins. Those CPUs like AMD and IBM Desktops we need to unassembled the same by tilting method. If your CPU pins are damaged, remove your CPU from heat sink by the help of a chisel type screw driver and clean both faces of heat sink and CPU. Do not scratch, use isopropyl alcohol to remove heat sink cement. Inspect any pins are dented or damaged. Align pins, if broken solder with help of a goldsmith. Reinsert the CPU in motherboard socket, apply a little portion heat sink cement in cpu face and re fix heat sink and recheck the motherboard.
Feb 12, 2011 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
I have a sharp lc 30hv6u that needs the avc system
There is no way around AVC, You will need it. unfortunately, it's expensive and hard to find.
Oct 22, 2009 | Sharp Aquos LC-30HV6U 30 in. HDTV-Ready...
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
When i start up the xbox it has no video, only sound.
Its possible for you to fix the problem your self.
how ever the fix may not last long .
Ok hear we go
find a video on how to strip the box down to the P.C. board.
pull the board out of the chaise by the small heat sink only
do not disturb the big heat sink at all or you will break the
seal an get 2 reds ( over heating)
Now that you have the main board in your hand
flip it over a carefully very carefully pry off the x clamp
bracket holding down the small heat sink for the G.P.U.
remove the heat sink from the board ,take out the four
studs under the heat sink . clean the gray heat sink off
the top of the two chips with rubbing alcahole ,do the
same with the heat sink then apply some heat sink compound
to the chips place the heat sink back on the chip
get four 10-32 by 3/8 long and EVENLY screw down
the heat sink Not too tightly ( snug not tight) .
Put the unit back together ,leave out the white fan
shroud plug everything back in and leave the fan
hanging out .
Now plug in the power and a/v cable place and hold
the fan over the Large heat sink for C.P.U. and turn on
the power .I should take 4-5 min till the fan gets up
to full then another 3-5 min to over heat Two red light
be ready to unplug the second this happens .
let it cool down for about 15-20 min and you should
have restored your video feed. I cant say how
long it will last .
if you have any questions feel free to email me
Rob
Take some heat sink compound
that you can buy from raido shack
now that that you have the main P.C. board in your hand.
Sep 18, 2009 | Microsoft Xbox 360 Console
Cpu fan's
One of the best sources I've found is www.mwave.com. You can check out their fans at:
http://www.mwave.com/mwave/dosearch_v2.asp?scriteria=cooling%20fan&bop=and&bbp=and&catpromotename=%filename%client-url%
I've bought from them for years and always had good results. If nothing else, you can find the type fan you need and then try and find it locally.
Good luck, and please let me know how it works out!
Feb 21, 2009 | AVC Computers & Internet
AVC DA09025T12UP Server - Round Fan Server Logo
222 people viewed this question
Top AVC Computers & Internet Experts
David Payne
David Payne
Are you an AVC Computer and Internet Expert? Answer questions, earn points and help others
