Question about Siemens 24 in. SL84A305UC Built-in Dishwasher
Siemens SF64M 330GB dishwasher won't shut off
Was working perfectly till one night we noticed it had not shut off after too long a session on 'light wash'. The machine was empy when the door was opened but it was making a soft pumping noise. Tried resetting it and this worked once on the very light rinse prog. Have cleaned and checked everything recommended in the handbook including resetting without success. Have the feeling it could take only a press on theright switches to restore it, as most of the usual noises are there!
danekeeper12
  • 6 Answers
SOURCE: SIEMENS SE64630GB NOT TAKING IN WATER
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Posted on Aug 15, 2008
tborn6
  • 700 Answers
SOURCE: Siemens Model SL84-A - Water will not pump into dishwasher
heres a screen on the inlet to the water solinoid that plugs up with calcium alot of the time. shut off the water and take the bottom panel off the unit and you will see where the solinoid is. take off the water and then take the solinoid out and apart to clean. reassemble and you will be good to go.
Posted on Jan 11, 2009
Krazytech
  • 725 Answers
SOURCE: Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Posted on Sep 19, 2009
  • 414 Answers
SOURCE: Siemens dishwasher pump runs while door open wont turn on!
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety and give the scenario you have described, so check valve, hoses etc for leaks. You will have to manual clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large tower and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch. https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Posted on Jul 12, 2010
BElectric
  • 1140 Answers
SOURCE: Hi. I have a
Hi -
The pump running continuously even with the door open means the anti-flood protection system has been activated. This is caused by one of the following:
- Defective or stuck float switch
- Stuck float
- Water leaking into the base of the machine
You're going to need to pull the washer out from under the counter to investigate. It's easiest to start by checking whether any water has leaked into the base. Switch the power off at the breaker/outlet and pull the washer all the way out.Then tilt the washer forward slowly to about 45 degrees with the door closed.
If water appears on the floor at the front of the washer, then water has leaked into the base of the machine. It's a good idea to put some old towels on the floor in front of the washer before doing this to absorb any water that comes out. Also, the washer is heavy and the bottom has a tendency to slide out, so get someone to help you tilt it, if possible.
If there is no sign of a leak, you need to remove the left side panel when facing the door and check the float. You'll need a Torx T20 screwdriver to remove the screws securing the panel - 2 at the front which are only visible with the door open and one at the back near the top of the panel. With the side panel removed, you should see an assembly similar to this one near the front corner:
I've ringed the float switch in red. This is activated by the red shaft running vertically below. You need to make sure the switch clicks on and off when you raise and lower the red lever. If the switch is stuck on it will need to be replaced. Hopefully, it's just stuck and raising and lowering it a few times will resolve the problem
Hope this helps. Please try this, then let me know if you need further assistance. Please also include the full model number - SL84A30 is incomplete and there are several possible models that could be your dishwasher. The full number will be something like SL84A305UC/12 and I will need to know this in the event that any replacement parts are required.
You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on May 03, 2011
Why isn't it powering up and all lights are staying on?
Check all the cables and make sure that they are plugged in tightly. After that I can't help you without more information.
May 11, 2015 | Siemens Speedstream 4200 Modem
Lg tromm washing machine
If the machine still works and that is the only problem I would use it till it doesn't, really they cost so much to fix sometimes
Sep 01, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Gorenje wa 72145 my son put washing up liquard in last night and the bubbles over flowed so i stoped the washer and empyed it. This morning iv gone to use it and f2 error comes up and wont work
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Jun 09, 2014 | Washing Machines
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
Siemans sl33a dishwasher won't drain, interior is scummy
My Siemens runs constantly, for hours, and doesn't drain all the water from the bottom. Is this also a "clogged drain" issue or is there something else wrong?
Jan 01, 2013 | Siemens Dishwashers
Aeg lavamat 54600 won't begin cycle
check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off you will see your pump undo the plastic screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Nov 02, 2012 | AEG Washing Machines
Siemens 24 in. SL84A305UC Built-in Dishwasher Logo
80 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
