Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica Minolta C350 - C-3751 Error Code
During printing we receive an error code of C-3751 and the printing stops. Any idea what is causing this and how to fix it?
We have restarted several times daily by holding the "Utility" button down during re-boot and clickinig "OK" on Trouble Resolve menue but this only temporarily resolves the issue.
How can we fix this?
Please help... Thank You!
    Problem Solver:
  • 17 Answers
The Fusing Roller Thermistor and Fusing Roller
Sub Thermistor are detected to be at a temperature
above 240 °C when the Main Power Switch IS ON U HAVE TO RESET THIS CODE
Posted on Jul 07, 2009
5 Suggested Answers
  • 5 Answers
SOURCE: error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Posted on Feb 19, 2010
Kevin Hayes
  • 167 Answers
SOURCE: I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Posted on Feb 17, 2009
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhubc552 error c8102
Here is the error code definition: C8102 Turn around pressure welding alienation trouble
•During a pressure motion being performed, the reverse roller sensor (PS7) output does not change from H to L. •During a retraction motion being performed, the reverse roller sensor (PS7) output does not change from L to H. Further research yields this possible fix, since this model is in the same family as yours: http://www.copytechnet.com/forums/konica-minolta/89213-konica-minolta-bizhub-452-error-code-c-8102-a.html
Apr 06, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta 8031
same issue never found solution... Konica rep came out and said he didn't know what it is then told me to lease a new machine... lol
c-3c30 = Designed Obsolescence
May 09, 2013 | Konica Minolta Bizhub 8031 Copier
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Apr 23, 2008 | Konica Minolta bizhub C450P Laser Printer
Minolta Di151 Error Code C-13
The trouble is that Minolta did not provide a chart of error codes in the user manual; mostly error code issues would require a technician to repair anyway -- or at least somebody trained to do preventive maintenance. If you have a routine repairman, or if you have My Konica-Minolta access, you should be able to get more information that way. Other things to check:
  • Is a preventive maintenance due?
  • What was the unit doing before it threw the code? Was it making copies? Of what quality? Did it stop in the middle or finish a run?
  • Are you using good quality, dry paper? This was posted in December -- might you be having static problems due to dry air?
If you're in the United States, you can check Konica-Minolta's Sales/Service Locator for a local repair outlet. Otherwise, you may need to contact Konica-Minolta directly.
Dec 26, 2007 | Minolta Di151 All-In-One Laser Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
2,352 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
