Question about Garden
How do I connect cleaner hose?
I am using a Craftman Pressure Washer and I have no manual. It has a compartment for a cleaner with a small plastic hose hanging from. I cannot figure out where this hose connects to.
  • David Ford
    David Ford May 11, 2010
    What is the exact model number for this and I will try and help
    New Friend:
  • 22 Answers
Right where the hose hook there should be a little hole in the back look good if you dont you will miss it if you dont see it turn the whole moter to the sibe where you can see it i hope i helped you have a bless one
Posted on Dec 21, 2012
    Sergeant:
  • 359 Answers
The hose simply is placed into the cleaner you are using ie bleach bluewolf ect iI have two just like the one you are talking about brought new and this is what the manual said to do , happy washing
Posted on Feb 01, 2009
Don't know how to get detergent into the ultimate x pressure washer (1500psi)
To the right of the Brass fitting where your garden hose attaches there is a small round plastic cover piece, pull on that and it will pull out a clear tube with it which goes into any container containing your detergent, it will pull the detergent as you use the pressure washer. Push the tube back in after you are done using it. You can also buy a replacement detergent bottle for other pressure washers if you wanted to.
Jun 05, 2011 | Garden
Small plastic hose on pressure washer where does it go? My grandson got to this washer and pulled it off - where I don't know.
There is a plastic hose that is for detergent injector that goes on valve body just below your pressure washer hose
May 15, 2011 | Psi Blue Max 2200 High Pressure Gas Power...
As it takes on water it overfills and leaks out of the drawer. An earlier answer suggests it is the pressure system. What is this and how do i fix it?
The pressure system you refer to, is the water level switch and pressure chamber, the small hose leading to the pressure switch can get blocked and cause the washer to overfill.
To check the hose, remove the lower rear panel of washer, at the bottom right you will see a large black hose, attached to this is the pressure chamber hose leading to the pressure switch.
Remove the small plastic hose and check for blockage here and in the black hose where the small hose is fastened too.
If it still overfills, then could be a faulty water level switch..
Dec 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My washer does not spray the cleaner solution as high as it did originally. The high pressure spray is fine.
If your pressure washer works like ours, it has a T connection.
A plastic hose comes off the T and goes into the bucket of cleaner
Pressure from the hose creates suction across the T and this draws cleaner into pressure hose
The plastic hose from cleaner connects to a small brass ball valve on the T
The ball valve clogs up or changes over time and cleaner will not draw up into the pressure hose.
We would replace the valve stem
I don't know if they sell the little replacement parts like they used to
Finally we had so much trouble.
We started applying our chemical with a pump-up sprayer.
For us, it was cheaper, and the work went faster.
We put one guy on the pump up sprayer
And then another guy came behind him on the washer.
Oct 25, 2010 | McCulloch FHH18A Electric Pressure Washer
How do we get the cleaner to go up the hose
We used to add a clorox mixture when we power-washed
There is a special fitting that goes on the power washer line
The fitting is a T with 2 quick connects that match your pump&hose quick connects
The T fitting attaches to pump >> the power washer line attaches to T
The T fitting has a short extension where you attach a plastic hose that goes to your bucket of clorox
The T has a small one-way ball valve that only lets clorox enter the power washer line, but power washer pressure doesn't escape into the clorox
The small ball will clog over time, so when you buy a T, see if you can get replacement part
When you pull the trigger, the pump pressure shoots water out of the gun
The water pressure shooting out of the gun creates a suction that draws up the clorox
The clorox enters the line and gets shot out of the gun
The same basic idea is used on shallow well pumps
We discovered after a few years that is was easier-to-control and cheaper to apply the clorox with a pump-up hand sprayer. We could apply more clorox. The machine was not exposed to chemicals.
Remember the engine draws-in surrounding vapors and those vapors can chew up the metal parts of any combustion surface.
Oct 19, 2010 | Black & Decker Garden
Do you put the clear hose in the bucket with the cleaner to get it to come out of the spray nozzel? If you dont use the low pressure attachment will the cleaner still come out or not? I cannot find an...
You must use the lowest pressure nozzle with the clear hose in the solution or you will not get soap. Make sure you use only the solutions approved for your pressure washer!.
Jul 02, 2010 | Briggs & Stratton Pressure Washer...
Where is the air filter?
it's located on the drivers side in front of motor,housed in large black plastic case with screws
Nov 22, 2009 | 1998 Dodge Caravan
The tubing from the gasoline is not connected
Devilbliss / Excell pressure washers in this model number range use a Honda GC160 engine. Information on this engine can be found here:
http://www.excellpressurewasher.com/documents/pdf/gc160.pdf
This web site also has information about the pump and related parts just look for your model number. I find that pressure washer manuals have very little information about the engine. Small engine / mower repair shops in your area will be happy to give you free information about the where the fuel line attaches. Your engine has a black plastic fuel pump with hoses going to tank and carb. This fuel pump is powered by engine crank/vacuum purssure so there is a third hose from the fuel pump connected to the engine block. Good luck on your repair and email if you have a question or if you have a different engine than mentioned above.
May 09, 2009 | Garden
Kenmore 70 series washer model 82870120 will not stop filling
you need to replace the water valve. This is a common problem and a very easy fix. You can order the part at sears.com via model number and also see a breakdown of the machine and how to put it in.
Mar 03, 2009 | Kenmore 23822 Top Load Washer
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
