Question about Compaq Presario 5000 PC Desktop
My computer wont open windows
2 days ago I got a pop up for one of those spy-ware programs that try to get you to download their software, I tried cancel out of it and I wasn’t able to. I couldn’t even get out of it through task manager. Everything was frozen up on my computer so I did a hard shut down. Now I can’t get into my computer at all. When I power up it brings up a screen saying that my computer was shut down improperly and it gives me the options to open windows normally, to restart my computer from the last time it worked properly, from safe mode, safe mode with networking, and another safe mode option that I cant remember off the top of my head as I am not at home in front of my computer. When I try to use the first 2 options it goes to the windows screen like its going to reboot but nothing happens it just stays at that screen. When I try any of the safe mode options it goes to a screen that looks like a DOS screen and it has the drivers rolling up the screen to the end then stops and then does nothing else and it is frozen in that screen. HELP!! I have tried everything I can think of and all I really need to be able to do is open windows normally so that I can fix the other problems. Can anyone help?
    Scholar:
    New Friend:
  • 42 Answers
Step 1: Removing recently added hardware
Use the steps in this section to disconnect any recently added hardware and test for the error.
NOTE: If a new internal device (sound card, hard drive, or other) was added to the computer before the error message started to occur, you have to remove it before continuing.
  1. Turn off the PC and unplug the power cord.
  2. Disconnect the mouse, and any other peripherals attached (Printer, scanner, webcam, zip drive, phone cord, network cable and other devices). Leave only the keyboard and monitor cable attached.
  3. Press and hold the power button on the front of the PC. Release after 10 seconds.
  4. Plug the power cord back in.
  5. Turn on the computer.
  6. The computer displays the We apologize for the inconvenience... message. Allow the timer to count down from 30 to 0.
  7. If the computer successfully starts to the Windows desktop and does not restart to the error message, connect one device and wait until Windows recognizes it.
  8. To find if a device is causing the error, continue connecting the devices, one at a time, restarting the computer each time, until the device that is causing the error is found.
NOTE: If this does not solve the issue try to do a system restore BUT it will delete all your files and programs you install by yourself after the system. You will be able to use the pc as a new pc.
Step 2: Restoring with System Restore
Use the steps in this section to restore Windows XP to an earlier time:
  1. Turn off the computer.
  2. Remove all attached devices except for the mouse, keyboard and monitor.
  3. Turn on the computer.
  4. When the We apologize for the inconvenience... message appears, use the UP or DOWN arrow key until Safe Mode with Command Prompt is highlighted and press Enter. NOTE: If the computer stops responding or restarts automatically, skip to Step 6 to restart from the last known good configuration.
  5. When the logon screen appears, select Administrator and enter the password (if applicable).
  6. When the command window appears, type: cd \windows\system32\restore and press Enter.
    Type: rstrui and press Enter. The System Restore screen will appear.
  7. On the Welcome to System Restore window, select Restore my computer to an earlier time , then click Next.
  8. On the Select a Restore Point window, select a date that is highlighted in bold print from the calendar.
  9. Select a restore point from the window labeled, On this list, click a restore point and click Next.
Please rate my solution.
Posted on Jan 22, 2009
  • Ganesan Chandraiah
    Ganesan Chandraiah Jan 25, 2009
    Performing a System Restore
    2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives,
    and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
    3. Turn on the computer and immediately press the F11 key repeatedly , about once every second, until Recovery Manager
    opens.
    4.Click Next . A Microsoft System Restore screen opens.
    5. Click Yes , and Next to continue the restoring process.
    Performing a System Recovery
    opens.
    4. Click Next . A Microsoft System Restore screen opens.
    5. Select No, I would like to see other options , and then click Next . A System recovery screen opens.
    6. Click Yes , and Next to continue the recovery process.
    7. The Recovery Manager gives you the option of backing up your data files, do so now if you wish.. To continue recovery, select No , and then click Next.
    8. A recovery progress screen opens. Wait while files are restored.
    9. When System Recovery is complete, click Finish.
    10. The computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes
    the setup.
    11. Turn off the computer, reconnect all peripheral devices, and turn on the computer. Before using the computer, update and
    protect it by reinstalling any virus and security software that was installed before the System Recovery.
    12. Reinstall any software applications that were added after purchasing the computer, and replace any files that were backed
    up.
    Scholar:
  • 170 Answers
The short answer....reinstall windows. Yes you well loose what is on your hard drive, but atleast you can use your computer.  Need more help? Let me know. Good Luck!
Posted on Jan 21, 2009
Computer and printer quit communicating. Lost printer icon on desktop. How do i reload printer software?
    Follow these steps to install the beta driver for your printer: From the Apple menu, select System Preferences. Highlight any Epson printersand click the button to remove them from the Printers list, then click OK. Select the folder labeled EPSON and drag it to the trash.
    How to Uninstall and Reinstall Your Printer Driver - Epson
    www.epson.com/cgi-bin/Store/support/supAdvice.jsp?noteoid... Epson
Jan 27, 2016 | HP Deskjet F340 All-In-One Printer
How to make my pc faster
1 . Clean up your desktop icons. Having too many icons on your desktop slows down your computer's operational speed. Consider cleaning them up to keep only what you need on your desktop.
2 . Remove unnecessary start-up entries. These are programs that start when you turn on your computer, and it takes time for them to load. Programs such as lime wire, Msn, and quick time helper are common culprits.
3 . Run a virus-scan. If you do not have any virus protection software, Then you can download it from the internet
4 . Un install any programs you don't use in Control Panel. Trial software and other junk clogs up your computer and makes it run slowly.
5 . Do a registry scan and repair. Using cleaner of your choice, clean and repair the Windows registry to make your computer run smoother.
6 . Conduct an ad-ware scan. Ad-ware is similar to spy ware and is just as bad. You can also download it from the internet
8 . Upgrade your computer's hardware. The most common upgrade is an upgrade in RAM, but you can also upgrade your graphics card or processor to make your computer run faster.
9 . Make sure all your hardware drivers are up to date. Do this by visiting the manufacturer's websites to download the latest versions.
10 . Turn off unnecessary visual effects such as Vista's Aero effect, all of which slow down your system. Skinning programs such as Windows Blinds also slow down your system.
11 . If all else fails, re-format your computer and install windows again to start off will a clean system with no junk.
12 . De fragment your hard-drives. When your hard drive is reading your files, a little head drops onto to a spinning disk to read the information to load a file. If the file is split up between multiple parts of the hard drive, it takes longer to open each file. Thus, De fragmenting frequently will make every-day activity quicker on your computer.
Hope the above information will help you.
Thanks.
Oct 10, 2010 | HP Pavilion m7480n (882780389410) PC...
HELO SIR , When ever i try to open any yahoo on internet explorer or try to open yahoo messenger a popup pops out saying yahoo services : yahoo has been banned. wat to do ? its most likely a trojan ,...
This A Particular Spy Ware That Acts Barrier From Opening The Program Windows. To Delete This Spy Ware Install The Bit Defender Antivirus.
Sep 19, 2010 | Yahoo Messenger
Slow computer
There are various other reasons like malicious programs being present in the system like Trojans, worms, viruses or spy ware software.
try this tool to fix the problem.
http://www.keep-pc-clean.com/
Apr 17, 2010 | Yahoo Messenger
Spysweeper hasn't updated in 80 days and keeps saying network connection failure, what should I do?
get rid of it ...and install a free avg with spy-ware protection and all ...it s updating daily ..and I had no problems with it in 2 years..they release a new version every few months and I'm content with the software ...its settable...for your own needs and reliable..
Nov 01, 2009 | Webroot Spy Sweeper (spysweeper) for PC
When I open Firefox my homepage (MSN) occasionally freezes. I cannot shut off the computer unless I hold the "On/Off" button for a few seconds then shuts off.
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} a:link, span.MsoHyperlink {color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {color:purple; text-decoration:underline; text-underline:single;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You might want to check your computer for spy ware programs and also clean your temporary files
For spyware try the next link, this is a freeware program that cleans most of the spyware programs:
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
To clean your temporary files try the next link, the CCleaner program is a freeware system that cleans all temporary files on your profile; also try the Registry cleaner that is included.
http://www.filehippo.com/download_ccleaner/
Good luck.
Oct 19, 2009 | Mozilla Firefox
Webroot spy ware
You will need to uninstall and install your program
Restart your computer--> black screen--> after the Bios check (is always the 1st step)--> start pressing the F8 key repeatedly--> Windows boot menu will apear--> use the arrows--> Safe mode
It will look different from you normal Windows (don't worry about this)--> go to Add / remove programs--> Uninstall your spysweeper program--> restart your computer normally--> install your program normally--> check for updates
Nov 07, 2008 | Webroot Spy Sweeper (spysweeper) for PC
First down explorer then firefox why is my p.c. killing my browsers?
By "Explorer" I'm assuming you mean Internet Explorer and not Windows Explorer, since you refer to other browsers. This sounds like you have gotten some viruses. Do you have anti-virus software installed? All Windows Defender does is protect against ad-ware and spy-ware or in simple terms, pop-ups. I would suggest you get a good anti-virus program and scan your system! By the way, you don't have to download anything to get viruses from the internet.
Aug 08, 2008 | Computers & Internet
Computer problem
virus protectors are like things in ancient world now days its spyware virus scanners lost there credibility to spyware programs cause spyware is quicker faster and they hide better but not from proper proggies
you need a strong firewall program like zone alarm
and spyware programs like spywareblaster and spy bot these programs are free bee's not shareware full functioning programs
you need to upgrade service pack 2 and internet explorer 7 with built in pop up blocker
wacovia pop ups are a phishing program looking to destroy comps these are spy ware and trojans hiding ready to strike once you get the recommended programs up these spy's should disapear
May 08, 2008 | Acer Aspire 5100 Notebook
New Printer not working with Windows Vista
Have you gone online and downloaded the driver from the lexmark.com site?
Have you turned OFF all anti virus software, firewalls and pop up blockers? Turn off programs like Spy Bot, Adaware and spy ware blockers. Spy Bot in particular will make that software hard to load.
It sounds to me like one of your security software programs are stopping your setup. That is a very common problem.
Mar 01, 2008 | Lexmark X1270 All-In-One InkJet Printer
Compaq Presario 5000 PC Desktop Logo
263 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
