Question about Bosch WFMC 3200 Front Load Washer
Is there a filter that I can clean out located behind the round cover on the lower right front of my Bosch Nexxt 500 series washer?  If so, how do I get the cover off?
  • 27 Answers
Just pop it off with a small srewdriver and yes you can get to the fluff filter through the round cover
when you open the filter there will be about two litres of water come out beware
Posted on Mar 12, 2009
    President:
  • 1,294 Answers
For majority of bosch washers, the filter is to be found behind a removable plastic panel at the front bottom of the washer; unscrew filter anti-clockwise, clean and refit .
Posted on Apr 08, 2009
Bosch washer will not spin
Check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Be prepared for a lot of water and junk. If you find a closed hose pipe when you remove the drop down flap it is to drain excess water.
The pump itself is directly behind the filter housing, check if there is nothing stuck in the housing, especially after you are cleaning out your filter after a long time. Clean out and refit carefully
Pl click if helped.
Mar 25, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Does this machine have a filter on the drain line? How do you access it?
The filter should be located at the bottom front right of the washer.
It may be behind a removeable plastic cover at the bottom of the washer.
Unscrew anti-clockwise to remove and clean.
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I am replacing the lock, what does the plastic rod hanging down from it do and does it need to be attached to anything
It attaches to a pull strap. The pull strap is in case the switch fails it can be pulled to get the door open. Most bosch pull straps are located behind the drain filter cover (lower right).
Oct 16, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Water remaining in the drum after cycle
Sounds like the filter needs to be cleaned
This is located at the bottom front right of washer behind drop down cover or flap.
Jan 15, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Clogged pump
You need to clean the filter.
This is usually located at the bottom right front of washer, behind a drop down cover, or removeable plastic trim.
Unscew anti-clockwise to remove and clean.
Hope this helps.
Dec 17, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a bosch washer about 3 years old. It suddenly stopped on spin cycle and water would not drain even when I put it to drain only. The motor chatters now like a car with a battery that is dead. Is this...
It does sound like the problem is related to the water pump.
The filter should be located at the bottom front right of washer, sometimes behind a removeable cover.
Locate filter, and remove by turning anti-clockwise, and clean, check inside the filter housing for anything in there as well.
Hope this helps.
Nov 30, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Sep 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Front loading washer does not advance past the rince cycle
Check and clean filter, it is usually located behind a plastic panel at the bottom front of the washer, remove cover and unscrew the filter cover anti clockwise, pull out and clean, replace and test, if it still does not drain, then possibly pump blocked or faulty.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch WFMC 3200 Front Load Washer Logo
521 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
